essex v6 cooling system
Results 1 to 7 of 7
    Rods 'n' Sods Junkie evildave's Avatar
    Sep 2010
    Norwich
    351
    25
    4
    evildave is offline
    Old Skool Ford :: View topic - essex running rough when hot
    have started a thread on old skool ford but hoping there's some essex v6 owners who may be able to give some advice on here?
    '68 Camaro RS 408ci
    '28 Roadster project
    Official RnS Addict chucks41's Avatar
    Jul 2010
    Thornaby
    1,253
    785
    chucks41 is offline
    I've read the other thread, one more daft little thing that might be worth checking is, is the timing slightly too far advanced, as it gets hot it could give the impression that the motors running lean because the mixture would pre detonate effectively giving the effect of advancing the timing further than it's set point. I'd possibly try retarding it a degree or two to see if that made any improvement.
    Just a thought off the top of my head.
    Good luck
    Chucks
    Too much time on my hands. Too little money in my pocket
    21,010
    Does the temp gauge ( matched sender and gauge hopefully ? ) read overly hot ? What is the V6 in and with what rad as they are notoriously difficult to cool.
    If all teh above pans out then 2 other options spring to mind, lack of return fuel line to tank IF the carb is set up for one or lack of phenolic spacer between manifold and carb. This was used to prevent vapurisation and fuel locks.
    Rodder through passion not fashion.
  5. #4
    xr8
    Rods 'n' Sods Junkie xr8's Avatar
    Mar 2010
    weston super mare
    408
    xr8 is offline
    i used to have 3 ltr capri a few years back with the same issue. i even fitted a holley instead of a webber. after spending quite a few quid the cure was????
    6 plugs. the ones that were in the car were the wrong temp ones.think they were colder running plugs for a pinto,although these fit they dont run hot enough there fore braking down when the engine reaches it normal temperature or above.
    if you havent tried that maybe worth looking into
    cheers
    snizzle your quizzle you mother
  6. #5
    Sep 2010
    Norwich
    351
    25
    4
    evildave is offline
    thanks for all the advice and tips, will try plumbing in the transfer hose, gauge and sender are matched and read accurate stat opens at 88degrees but gauge spikes to 100degrees when stat opens electric fan starts at 95degrees and cuts out about 90degreees when falling, plugs are for a v6 and new from burtons. when its running ok i'm going to put it on the rollers and check fueling set up etc. oh it's all in a dolomite sprint and has a 'big' radiator from god knows what.
    '68 Camaro RS 408ci
  7. #6
    I'm a grown up member now ! Crank 2's Avatar
    Mar 2010
    South East
    46
    Crank 2 is offline
    Try the timing first. Then progress to the thermostat and fans.
  8. #7
    Sep 2010
    Norwich
    351
    25
    4
    evildave is offline
    I did have a lot of debris in the dizzy cap once so really i guess that should be pulled and cleaned out as well, a good time to do the timing. That'll be a new one for me, never attempted it
    '68 Camaro RS 408ci
Please select your insurance company (Optional)
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
  1. Southend Cruise & Essex Memories
    By THE POP SHOP in forum History Archive
    Last Post: 12-01-2015, 22:42
  2. Cooling system
    By CRAIG in forum Tech Discussion
    Last Post: 01-09-2010, 15:42
  3. Essex boy!
    By pottsy in forum Who are ya ??
    Last Post: 26-05-2010, 01:48
  4. manningtre essex.. car show..this sunday
    By bigted in forum What, Where, When ?
    Last Post: 24-04-2009, 07:32
