Fuel pump query
Results 1 to 5 of 5
Thread: Fuel pump query
    Official RnS Addict D COUPE's Avatar
    WEST YORKSHIRE
    511
    33
    D COUPE is offline
    Fuel pump query
    The first of many lads get ready.
    I have a rover 4.0 engine with a webber on top. I have a Carter fuel pump P4070.
    Do I need a fuel return pipe. The webber only as inlet.....
    Thanks
    ITS NOT WHAT YOU DRIVE ITS HOW GOOD YOU LOOK IN IT
    Jun 2016
    Roswell, New Mexico
    216
    NMNeil is offline
    As a rule of thumb a carb only needs a fuel feed. An injected engine uses a return line because it needs to keep air and vapour bubbles out of the injector, and the pressure regulator needs to vent fuel back to the tank.
    WEST YORKSHIRE
    511
    33
    D COUPE is offline
    Thanks for that . Will the pump switch off when it gets up to pressure or will it run all the time .
    Jun 2016
    Roswell, New Mexico
    216
    NMNeil is offline
    Not sure but the blurb says it has an internal pressure regulator. At a guess it will run all the time as the maximum current draw on an electric motor and the most wear occurs as it turns on.
    Dec 2012
    winsford
    280
    201
    boblester40 is offline
    As long as the pump does not produce to much pressure for the carb it should be ok , However in this case i would check the specification of the pump also to see what it requires as some pumps require a return flow to keep them cool .
Please select your insurance company (Optional)
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
  1. Pontiac LS2 fuel pump query
    By alan in forum Tech Discussion
    Last Post: 06-02-2014, 21:16
  2. Fuel cell & pinto mechanical/electric fuel pump query...
    By RockinRodder in forum Tech Discussion
    Last Post: 05-01-2013, 21:31
  3. electric fuel pump ?
    Last Post: 02-11-2009, 17:45
  4. fuel pump
    By 58 delray in forum Tech Discussion
    Last Post: 13-09-2009, 07:51
  5. Fuel pump advise please
    By 56 AUSTIN in forum On Topic
    Last Post: 07-06-2009, 19:49
