Making a momentary switch into latching ?
Results 1 to 10 of 10
    20,774
    Yes, I know it would be easier to buy a latching switch in the first place but I'm not finding what I want . Does anyone have a circuit of how to make a momentary switch 'latch' via relays etc ?
    Rodder through passion not fashion.
    Jan 2010
    kilmarnock
    250
    93fxdl is offline
    not being an electriceral type i cannot provide concise info but there are latching relays which once switced with a pulse stay there until pulsed again when they open
    off the wall maybe but would a headlamp relay do the job as a some cars have a momentary switch to swap between high and low
    hope this helps
    ttfn glenn
    YamYam central
    3,490
    453
    74
    sidspop is offline
    I can try to describe it, may not make that much sense though Kev!
    Take poitive feed to coil via momentary switch, with negative to other side of coil.
    Take positive feed to relay connector.
    Take switched positive to load, and also back to coil positive.
    Thus when pushing switch, the coil energises, putting volts on the guzouter pin. That is also fed back to the coil guziner, keeping it energised.
    I would have drawn a comic, but can't find the program I want.
    Make sense??
    Andy
  5. #4
    20,774
    Understand that bit Andy ( surprisingly ! )but how how does it turn back off , another relay closing one of the other circuits on the first relay?
  6. #5
    south east kent
    890
    35
    THE VIKING is offline
    Here you go kev should find what you are after here
    http://www.the12volt.com/relays/relays.asp
  7. #6
    south east kent
    890
    35
  8. #7
    YamYam central
    3,490
    453
    74
    sidspop is offline
    What application do you want it for?
  9. #8
    Nr. Dartford, Kent
    2,345
    242
    stueeee is online now
    Quote Originally Posted by THE VIKING View Post
    This one allows the use the same switch to turn off and turn on
    http://www.the12volt.com/relays/page5.asp#lsp
    Stuart.
    My Intro
  10. #9
    Feb 2010
    london
    458
    zephyrc is offline
    seems a little pointless to use 4-5 other relays instead of one latching relay,, especially when the latching relay is readily available
  11. #10
    20,774
    Thanks for all the help guys, I've been distracted at the mo as I need to sort Marians Figaro misfire .
Please select your insurance company (Optional)
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
  1. Making a p-u out of a Y sedan.....
    By Survivor mike in forum The Garage
    Last Post: 27-01-2011, 20:43
  2. Adjustable pressure switch
    By kapri in forum On Topic
    Last Post: 18-03-2010, 20:04
  3. mk5 cortina switch gear
    By rootesix66 in forum Stuff - WANTED
    Last Post: 11-02-2010, 21:10
  4. single wire cooling fan switch
    By dek in forum Tech Discussion
    Last Post: 28-12-2009, 10:54
  5. Thermo switch
    Last Post: 29-04-2009, 18:59
