Prefect handbrake
Results 1 to 4 of 4
    Jun 2011
    Essex
    1,065
    606
    Perfect65 is offline
    Prefect handbrake
    Before I go off on my own furrow, making up handbrake cables and parts I though I would just see if one of you has already done something same or similar. I have upright Prefect with Anglia axle under the standard transverse spring. I want to use the standard walking stick handbrake lever under the dash. I want to use twin cables from the axle and already have suitable brackets fitted for this pulling the original type brake levers using 1/4" pins and clevises. So I will run the cables forward to a point roughly by the back of the gearbox as this is handy to mount the relay lever and tension balancing unit. I understand the relay lever should give additional leverage and length of pull to suit the walking stick. So, has anyone done something similar on this car or a Pop or an Anglia? and if so did you use a donor cable(s) or make up the whole thing from parts. I am ok making a cable as done many for big capacity bikes and the clutch cable for one of those is about the size I imagine.
    I have been searching the net and ebay for parts but nearest yet is Venills but the cable listed is only up to 2 or 2.5mm and I am thinking 3mm perhaps plus a chunky outer sleeve. Has anyone any suggestions for a supplier of cable and clevises etc so I can source the right bits? - Dave
    Jun 2011
    Essex
    1,065
    606
    Quote Originally Posted by Perfect65 View Post
    Looks like I will have to start ploughing soon on my own.
    Pass the lump hammer Blown 100e's Avatar
    Earl Shilton
    549
    30
    Blown 100e is offline
  5. #4
    Jun 2011
    Essex
    1,065
    606
    This where I have got to so far. I will make my own cables initially using materials from JJ or Venhill and when I am happy with the result get a set made by the professionals. The compenator/relay assembly I will make and it will be constructed using a sandwich of 3mm steel plates as the bread. The filling will be a Triumph Spitfire relay lever pulling a steel strap with balance bar on the end which in turn has the two cables to the rear brakes attached. On the back axle I already have cable stop brackets in line with the Anglia handbrake links. The sandwich box will be attached in the area between the ladder bar cross member and the gearbox mount. The handbrake lever, the original umbrella stick, will be angled to exit more to the left due to new engine being where it originally passed through the firewall but this gives I think a better line of pull for the driver anyway. At the moment I am trying to work out the best ratio for the relay lever and guessing about 5:1. Advantage of the sandwich box is I can 'hang' it almost anywhere and it should be weather and dirt resistant.
Please select your insurance company (Optional)
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
  1. Prefect/Pop handbrake
    By Perfect65 in forum Tech Discussion
    Last Post: 03-09-2011, 22:15
  2. Pop 103E or Prefect Handbrake handle
    By THE POP SHOP in forum Stuff - WANTED
    Last Post: 20-03-2010, 00:32
  3. needa100e's prefect
    By needa100e in forum The Garage
    Last Post: 26-05-2009, 17:35
  4. Handbrake lever
    By Mark H in forum Stuff - WANTED
    Last Post: 26-04-2009, 09:37
  5. ford pop handbrake
    Last Post: 22-04-2009, 20:00
