rack n pinion steering
Results 1 to 10 of 15
    Jan 2010
    Toulouse, France
    3,351
    DjNeil is offline
    is there any way to adjust aftermarket rack n pinion steering to give a better turning circle.
    With its old steering box it was 5 1/4 turns of the wheel lock to lock and with the new rack n pinion its 3 1/2.
    Thanks
    Dec 2012
    winsford
    286
    211
    boblester40 is offline
    Quite simply no , the ratio is set by rack and pinion , you would have to change both of these to be able to effect the ratio and to my knowledge this cant be done .
    21,256
    Turning circle will be dictated by wheelbase and the full lock of suspension . Length of rack ,and therefore available internal lock to lock , is dictated by internal stops . If the wheels reach the same point as before hen you are talking about steering 'quickness /weight' rather than lock.
    Rodder through passion not fashion.
    Jan 2010
    Toulouse, France
    3,351
    DjNeil is offline
    thanks for the replies
    its not got the same turning circle so the wheels don't reach the same point as it had pre rack n pinion.
    I don't know the make but i'll take a good look tomorrow and see if i can get any numbers off it and contact the manufacturer
    I'm having to do a 3 point turn to turn tight corners
    nowhere
    5,677
    1925
    nobody is offline
    Possibly but depends on the rack.if theres enough keyways !!! on the inner shaft , the outer could be shortened.this would give you a better turning circle.
    The downside is you may have to re do the rack mounts .you would also have to make sure theres enough room for the tires to turn to full lock
    Jan 2010
    Toulouse, France
    3,351
    DjNeil is offline
    I'll take some photos tomorrow and see if you guys can figure it out. I could work out how to fit it but don't want to start modifying it with my limited front end knowledge
    Rods 'n' Sods Junkie DEVONMAN's Avatar
    Oct 2010
    Croydon
    268
    7
    DEVONMAN is offline
    Shorter steering arms will give a smaller turning circle. But finding some with the correct fitment may be difficult.
    The amount a rack moves from left to right has little to do with the turns at the steering wheel. You probably need to find a rack from a car with similar length steering arms to your existing ones.
    Whats the car ?
    nowhere
    5,677
    1925
    nobody is offline
    Shorter steering arms will move the rack pivot points and could cause bump steer.
    Glasgow,Scotland
    2,122
    german8rcoupe is offline
    I think he is referring to the arms on the upright Wayne.
    If the rack has bolt on drumstick type tie rods, then these can be machined to go deeper into the rack body or the rack body can be bored out more for them to go in more....depends on the rack.
    9,903
    yes i thought he meant the arms on the uprights not on the rack too.
Please select your insurance company (Optional)
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
  1. Rack and pinion steering conversion- Idler?
    By Street in forum Tech Discussion
    Last Post: 25-01-2015, 14:39
  2. Mustang Rack & Pinion Steering
    By Stang Man in forum Stuff - FOR SALE
    Last Post: 04-10-2014, 19:08
  3. Replies: 8
    Last Post: 21-03-2013, 01:21
  4. 57 Chevy rack and pinion steering
    By series1 in forum Stuff - FOR SALE
    Last Post: 14-02-2011, 20:57
  5. New - Mustang 2 rack and pinion - £180
    By Jon Connolly in forum Stuff - FOR SALE
    Last Post: 12-09-2010, 13:02
