home made Slingshot tube shifter
Results 1 to 4 of 4
    Rods 'n' Sods Junkie mfp-66's Avatar
    Apr 2010
    cumbria
    328
    173
    mfp-66 is offline
    came up my own version of a tube type shifter out of scrap i had lying about the garage.
    used a section of 80's mustang column to provide the outer and inner parts
    used the double d section as well as it matching outer section
    on the inner section i welded a small section of square bar. this will be the reverse lock out
    i cut a corresponding slot in the outer tube for the square bar to slide in to
    welded on an end plate that mounts a spring loaded lever
    the lever stops the shifter pulling into reverse
    slotted the end to fit a ball joint. welded it to the column bracket on the top of the axle case
    using tube to connect shifter to bracket on the box with ball joints at either end
    the cockpit end will have a shift knob fitted
    I was thinking of mounting the neutral switch on the side with a hole in the outer sleeve, the inner will have a dimple when the shifter is in the neutral position
    still not completely finished but it seems to work OK. does require both hands to select reverse but i can live with that
    Official RnS Addict fad15's Avatar
    Mar 2012
    bucks
    6,015
    8
    fad15 is offline
    Good to know there are still thinkers out there.
    built by hand NOT by computer
    Apr 2010
    cumbria
    328
    173
    mfp-66 is offline
    sometimes i do too much thinking and not enough doing!!
    Rods 'n' Sods Junkie woodie's Avatar
    Jan 2011
    Rugby.....
    413
    30
    woodie is offline
    nice thinking & work ! how long before its on the strip?
    Happy days...
Please select your insurance company (Optional)
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
  1. Home Made Vans thread
    By hurnleft in forum History Archive
    Last Post: 15-02-2012, 12:43
  2. Home made front clip
    By Iggy in forum Tech Discussion
    Last Post: 09-02-2011, 13:09
  3. Home made english wheel,romford
    By fester426 in forum Stuff - FOR SALE
    Last Post: 22-03-2010, 00:29
  4. Slingshot tube specs
    Last Post: 19-03-2010, 10:41
  5. home made tube bender.
    By stumpy in forum On Topic
    Last Post: 26-04-2009, 16:47
