looked around locally for a company to punch some louvres in a vintage panel, eventually found somewhere but there tool was chiped and pretty tired looking and the flypress throat wasnt really deep enough..
I had a look around and picked some brains ( thanks Paul) and eventually decided to go it alone.
For the louvres I needed i was quoted £360 plus vat, so sourcd a company in the UK and bought the tooling.
Searching the net I found a design for a presss frame that seemed to meet most folks needs, it was stiff uncomplicated and worked.. albeit most users noted that the frame throat flexed a little before punching the louvre .
Most of there machines were made to feed into the back of the throat, with the throats being on averge 48 to 53 inches deep.
This one stands 6ft tall and has a 36inch throat.
My thinking was that a shallower throat frame built with the same material they used for the bigger machines would be stiffer, so thats the route I decided to pursue.
I bought a compete length of 100x100 x 6 box section ( £100 ) and drew out the full size frame on the garage floor .
Over the next couple of days, when i managed to get a spare minute I cut the box section to suit the dimension of the frame, typically in 16 inches short, but should manage to turn that up at the scrapy..ad pick up some material for gussets.. might eventually sheet the whole thing in 1/4 plate, but waiting to see how it performs when its fuly assembled.
I decided to use a hydraulic cylinder to push on a slide that holds the louvre punch. The slide mechanism is at a local engineer shop, It comprises of a back plate, 2x 1 3/4 guides an 1 3/4 slide/ram. and a cover plate. this lot will be bolted to a face plate that will be weded to the main frame. The idea is that the louvre tool can be removed and other bits bolted to the face plate..maybee!
Unfortunately I dont know how far on they re wth the job but the basic frame is pretty much complete..
The cost for this lot will be in the region of £750, but between the job its being built for and one in the pipeline, its already almost paid for.
I dont intend to offer a louvre service, this tool is prety much for my own use nd my desire to be self sufficient..
Pics of the frame attached..
LinkBack URL
About LinkBacks
