    Official RnS Addict mikeyboy's Avatar
    San Diego.Calif USA
    1,133
    44
    Storing an engine for long periods
    If its in the car,run it to operating temp and slowly pour some ATF down the carb.As soon as you see white smoke out the exhaust turn the engine off. Your cylinders and valves are now lubed for lengthy storage. Good to go.
    There's no replacement for displacement.
  2. Register to remove these ads
    I'm a newbie !
    Jan 2010
    Barnet herts
    15
    Think i#ll pass on that one , thanks all the same.
    Nov 2009
    Huddersfield, UK.
    96
    6
    What the hell?? Really? Run ATF into your engine?? Are you mad?
    Why not just store it under a big plastic sheet, on a wooden pallet (so off the floor and kept dry) in a garage?
  5. #4
    margate
    41
    2
    a couple off caps of redex down the plugholes turn engine over buy hand a couple of times and replace the plugs job done
  6. #5
    Muppet blackpopracing's Avatar
    628
    91
    What about valve spring crush? engine needs to be turned regularly or the rockers need to be unwound to relieve the spring tension.
    Otherwise, just pour some oil down the plug holes and loosely put the plugs back.
    Before restarting take the rockers off and pour oil over all the valvetrain, bring pump pressure up with a drill & tool down the dizzy drive and re start.
    Just my humble opinion.
  7. #6
    I'm a newbie !
    Jan 2010
    Barnet herts
    15
    & when yer ready for fire up tear the motor down to unsieze rings/lands , ATF will varnish well below cylinder temps.
  8. #7
    Rods 'n' Sods Junkie 100ev8's Avatar
    wolves
    439
    66
    change the oil before lay up !!! old oil contains acid and eats metal . take a look at feeler gauges that have been used on petrol engine, they get etched with the acid
  9. #8
    San Diego.Calif USA
    1,133
    44
    Quote Originally Posted by 100ev8 View Post
    Yes.I meant to add fresh oil in my post. Well a very reputable engine builder in California told me that.
  10. #9
    watford
    543
    I agree with all the points made by Blackpopracing. I have a few in long term storage and I make a point of re-oiling the bores with an oil can and heavy engine oil from time to time and give them a few turns by hand [or even spin them over with the plugs out and a starter and jump leads to get the oil round them]. never had a problem with valve springs.
  11. #10
    Sep 2009
    london
    56
    i always refresh the oil and filter for a long layup and remove the plugs and spray loads of wd40 down the bores and replace the plugs. its also very important to turn the engine over pperiodically to keep every thing free. thats what i do anyway.
  1. a long shot but.........
    By chris in forum Stuff - WANTED
    Last Post: 18-05-2010, 07:46 PM
  2. Replies: 10
    Last Post: 02-05-2010, 01:09 PM
  3. ford 460ci big block engine long or short!
    By Ken in forum Stuff - WANTED
    Last Post: 02-04-2010, 03:10 PM
  4. Long way down......
    By Shedster in forum Chat
    Last Post: 30-03-2010, 01:52 PM
  5. The late rob long
    By Vivaline in forum Chat
    Last Post: 10-11-2009, 09:24 PM
  • You may not post new threads
  • You may not post replies
