100e Escort Gasser Build
Page 1 of 22 1 2 3 11 ... LastLast
Results 1 to 10 of 212
    Rods 'n' Sods Junkie matt100e's Avatar
    Jul 2009
    Stroud
    267
    17
    matt100e is offline
    Right then, its been a busy couple of weeks...
    After speaking to my Stepdad (Pete of Lite Welding Ltd) it was decided it was time to build a car 'for me' rather than buying cars that were done / nearly done and then finishing/changing them to how i wanted them to be.
    The plan was set I would find the body / running gear for what i wanted and Pete would then get it to the rolling stage with all the major fabrication work etc done ready for me to finish plumbing it and wiring it etc.
    So here goes...
    After lots of looking at this for inspiration:
    I found this:
    Then decided to spend a day in Leicester buying this, to steal the running gear:
    The plan is to get all the major components together, then get it down the workshop asap for mocking up and to start work.
    So far I have the body, chassis, rear axle, engine and box, and front suspension (Just need to get them stripped out )
    Still looking for a set of both front and rear slot mags - Rears need to be 7-8" wide can be any stud pattern as I will need to get a set of half shafts made up.Fronts need to be as thin as possible and preferably 4 stud ford 108mm, what you guys got?
    The car already has its name: 'Maggie's Gold', thought of by my mother of all people. The reasoning behind the nameis a personal one, my Gran passed away last year and her name was Margerat hence the 'Maggie' and the 'Gold' is down to the fact some of the money that was left to me is being invested in the car (though not according to my gramp :whistle.)
    How things look so far, everything tucked away in the garage:
    More to follow as parts are collected /stripped etc and the buiulding starts, hope you guys enjoy and can help out with all the questions 'I WILL' be asking.
    Cheers, Matt
    sjb
    Nostalgia freak sjb's Avatar
    essex uk
    4,994
    1862
    sjb is offline
    Im looking forward to this thread
    did you see this one i posted from the late 80s...
    or the one on the hamb
    http://www.jalopyjournal.com/forum/s...d.php?t=254938
    Jul 2009
    Stroud
    267
    17
    matt100e is offline
    Brilliant, no not seen either, ill add them to the inspiration file! Thanks
    Cheltenham
    4,076
    601
    fozwanger is offline
    Matt,
    Spoke to Wayne today about your axle, it'll be an 8", he can narrow it for you but he'll have to make up a load of tooling to do so.
    Also been speaking to Pete about the proposed front end, still chewing a few things over about the proposed set up, I'll keep thinking about it and let you know.
    Jul 2009
    Stroud
    267
    17
    matt100e is offline
    Cheers Jeff, Ill speak to Pete and Wayne about narrowing the axle! Just gotta get some Nice Slots sorted next.
    Got a quote back off Hausers for new halfshafts, worked out about £450ish i think for the pair with bearings and studs, not too bad.
    Thanks for helping with the front end setup be ace if it turns out to work, being able to have the look we want but without the expense of a whole new front end. Just had a look and the Mustang does have Mcpherson Struts.
    Sep 2009
    rothes scotland
    1,192
    149
    Duncan is offline
    no isay no boy i wanna be the first to build a proper gasser escort its just not fair
    cw motors paint and body little woody's Avatar
    manchester
    311
    7
    little woody is offline
    the father in law is underway with a 300e van gasser,with all the proper straight tube front end etc.the pic of the saloon and the prefect is smart ,good inspiration .my dad has a escort like yours but hes going the pro street look good luck with the build
    Lee
    Fat 'n' Loud Lee's Avatar
    Derby
    4,766
    493
    Lee is offline
    Have you got any of the Mustang left?
    I might be interested in a few bits.
    (p.s. YOU MURDERER!!)
    Rods 'n' Sods Junkie derek 33 ford's Avatar
    middleton manchester
    398
    7
    derek 33 ford is offline
    Smilegasser
    good on you the more the better if you go into my album there are some early picks of my 300e van its a long way on from the picks but still a long way off but it should get there by the end of the year? all the best derek (little woodys father in law) keep it in the family.
    Jul 2009
    Stroud
    267
    17
    matt100e is offline
    Hi Lee, All im using from the car is the axle/rear suspension, box, engine, radiator, pedal box and any bits i can use from the front suspension. The rest will be up for grabs,once its been stripped the interior is absolutly superb was going to put it up on the mustang forums.
    Ill have a look at the pics cheers Woody and Derick! The car is going to be my daily and as such there will have to be compromises made, We have some cool ideas for getting round the front end set up! Which will be revealed as the build progresses (As long as it works )
    And sorry Duncan, a mans gotta do what a mans gotta do!
    1. mk2 escort front end in a ford 100e
      By 55prefeect in forum Tech Discussion
      Last Post: 16-08-2013, 23:41
    2. m1 2 door ford escort 427ci build
      By v8escort in forum The Garage
      Last Post: 19-08-2011, 22:27
    3. My 100e gasser project
      By hotrodtom in forum The Garage
      Last Post: 16-03-2011, 21:11
    4. Replies: 0
      Last Post: 21-05-2010, 18:52
    5. My kit build
      By 57peppershaker in forum The Shelf
      Last Post: 17-02-2010, 12:19
