1932 ford pick up
Page 1 of 10 1 2 3 ... LastLast
Results 1 to 10 of 94
    Official RnS Addict Nobler's Avatar
    london
    1,310
    150
    Nobler is offline
    1932 ford pick up
    Hello,
    starting a 1932 ford pick up, well I say that, its going to be a 34 on 32 rails.
    need doors, thanks to Mr. P for the importing, OH and Mr. G on t'other side
    Rods 'n' Sods Junkie jimmy the pump's Avatar
    Feb 2011
    tonbridge
    112
    22
    jimmy the pump is offline
    I think there's a bit missing
    Official RnS Addict dutchrod's Avatar
    netherlands
    4,088
    132
    dutchrod is offline
    Quote Originally Posted by jimmy the pump View Post
    nah, thats mint condition, no rust and complete. for restauration only
    teach your children to think, not what to think.
    I am different, just like you.
    nowhere
    6,821
    2357
    nobody is offline
    Good luck,just dont try to over complicate it like youre other builds.
    Look forward to seeing it progress
    12,922
    where's the fun in buying bits that fit when you can spend thousands of hours trying to get parts 50p cheaper to work instead. the wheel didn't invent itself you know wayne
    only kidding nobler, hope this one goes well
    I'm a newbie !
    Mar 2014
    erskine, glasgow, scotland
    15
    bubbalardass is offline
    good luck!
    london
    1,310
    150
    Nobler is offline
    fenderless it is then, for sale 32 ford headlight bar and fender props.......................
    oh p.s. thank Mr. G
    london
    1,310
    150
    Nobler is offline
    need ford 8/9 inch small bearing 10 inch brake wheels studs
    NEED 10 - though I had two sets, but they are the bigger shank type
    ALSO need 4 3/8ths t-bolts, have a set with small heads and no good
    p.s. 1970-75 ford maverick 8'' maybe comet too = 56.5'' wide
    one is 25 3/4
    the other is
    29. 3/4
    stock they luckily have 3/8ths extra to the back of the spline, which means you can remove 1/4'' and have yourself a 56'' wide axle.
    you only actually need nibble 1/8th from each end - you still have 1 / 16 to 1/8 float
    56 inch wide
    all stock giblets
    typically got new drums shoes wheel cylinders 4.11's bearings, short 1310 pinion yoke and have fallen foul of the bloody wheel studs which have fell out the box
    also the 3/8ths t-bolts half of which are somewhere between ohio and london via new jersey and luton
    I should't have sold all me bloody half shafts, silly chunt
    anyone on hare with a plasma table running sheet-cam and mach3? - can i send yo9u sheet-cam files for you top plasma 5mm tabs and doofers or, anyone in west london have a pilot arc plasma and a compressor - I can bring a mobile plasma cnc to, saving up for a hydro-vane
    thanks
    oh yes, what ever you do DON'T spin off the tube from a tapered tube 9'' and try to re-insert it as its too big, from the factory they bore the tube so it slips in, you will spend hours with a drill and a flappy doo darr opening up the tube.
    will look quite stock though when you do and you will not have a your butt welded, plus the point being you can set everything up and still pull the end off, IF you like you can actually do a full wrap control arm tab combined shock mount.
    Well thats the plan
    london
    1,310
    150
    Nobler is offline
    Old Car World Perivale 020 8810 4595 - American car spares just off the a40 behind the hoover building
    happened to have a pair of old stock 10'' back plates for 2.5'' drums = great
    john woolfe racing happened to have a pair of 10'' ford ltd rear drums = great
    so IF you happen to have a small bearing ford 8 or nine inch axle, and you have the 2.78'' hub register, simply buy some 1.5 offset backplates, 1980 Lincoln drums and upgrade your brakes, and get a finned drum too boot - especially if you are running a solid wheel
    london
    1,310
    150
    Nobler is offline
    If you happen to buy a 1993/4/5 s10 or tvr t5 tremec tail housing like the picture, with the remote further forward, take note, the tone ring or machined boss for the speedo drive on them is in a different postion on the shaft than both a mustang and Camaro,
    i.e. wanted a world class output shaft from a 1994 t5 !!!
    also wanted - >1993 ford mustang bell housing - sandwich plate and fork,
    plus I need a bare block
    oh and still need 4 small bearing back plate t-bots
    take a ford late 10.5'' flywheel too
    1. 1932 Ford pickup
      By 35kid in forum Vehicles - FOR SALE
      Last Post: 04-09-2014, 21:35
    2. Miller Hauler Special- 1932 Ford Pick-up
      By stinger in forum The Showroom
      Last Post: 10-05-2011, 18:32
    3. 1932 Ford Firewall - Original
      By Clarky in forum Stuff - FOR SALE
      Last Post: 13-08-2010, 12:49
    4. 1932 Ford Roadster
      By Clarky in forum The Garage
      Last Post: 10-08-2010, 15:15
    5. 1932 Ford Coupe project must inc V5
      Last Post: 03-06-2009, 13:59
