1932 ford pick up - Page 10
Page 10 of 10 FirstFirst ... 8 9 10
Results 91 to 94 of 94
  1. #91
    Official RnS Addict Nobler's Avatar
    london
    1,310
    150
    Nobler is offline
    here we have a 70's Chevrolet c10 etc pick up steering gear box, basically a Saginaw 525 steering gear, but with the mounting bosses on the other side.
    right hand input worm and nut. sector shaft spline size is 1 1/16 - vega is 1'', power steering is 1 1/8 - note-the small gm 605 power boxes are 1 1/16''
    It has been fitted with a 70's Chevrolet corvette input worm, from the long sector Saginaw 525, its ratio is 16-1 - short stub input @ 30 splines 3/4'' fat
    it has a 1970's Chevrolet Camaro pitmann arm, these are 6'' on centres (they are available 7'' from the 605) it has a 1/2 inch drop, and stock takes the 7 degree taper
    similarily used on early ford tie rod ends
    one turn of input = 65mm or 2.5 inches of travel, so lock to lock is 2 turns, which is nice.
    note to self, you need a 7/8ths seamless tube 4.88 wall tie rod at 30.5 inches long, drilled 5/8ths and tapped - 3 stage tapped, 11/16 - 18tpi
  3. #92
    london
    1,310
    150
    Nobler is offline
    forgot to add...
    steering shaft now goes under the exhaust, comes out in the stock 32 location, need to squeeze in three pedals......
  4. #93
    nowhere
    6,828
    2363
    nobody is offline
    finally
    do we now have two years of you going through 17,000 different pedal ratio combinations,befor you settle on one that's been done befor
    did you sort out the steering link.might be worth contacting a few local machine shops to sort out youre odd thread size bits.i have a good one local
  6. #94
    Official RnS Addict 55zephyr's Avatar
    Mar 2010
    Brentwood
    509
    138
    14
    55zephyr is offline
    I just knew the attention to detail would pay off in the end.
    Ron.
    Older but no wiser.
  1. 1932 Ford pickup
    By 35kid in forum Vehicles - FOR SALE
    Last Post: 04-09-2014, 21:35
  2. Miller Hauler Special- 1932 Ford Pick-up
    By stinger in forum The Showroom
    Last Post: 10-05-2011, 18:32
  3. 1932 Ford Firewall - Original
    By Clarky in forum Stuff - FOR SALE
    Last Post: 13-08-2010, 12:49
  4. 1932 Ford Roadster
    By Clarky in forum The Garage
    Last Post: 10-08-2010, 15:15
  5. 1932 Ford Coupe project must inc V5
    Last Post: 03-06-2009, 13:59
