1932 Ford Roadster
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 78
    Essex
    230
    Clarky is offline
    1932 Ford Roadster
    After looking for some months for a suitable project to start me down the path of building a hot rod I finally found something that I could afford and needed loads of work which means I can still get my hands dirty for quite a while.
    I took delivery of a '32 Ford chassis setup with front and rear Model A crossmembers, an original '32 K crossmember and stainless steel spreader bars.
    The chassis has been tacked and bolted together so I can finish off the welding and prep for paint.
    As part of the package I also bought a '32 firewall, '34 steering box/pitman arm, '34 column, '40 column cover, '34 pedal assembly, a dual port master cylinder and a few bits 'n bobs.
    So up on the trestles it went so I could strip off all the parts so I could clean up the chassis and remove all the red paint.
    Which left me with this pile of bits....................
    http://www.thirtieshotrod.com/images...tripped002.jpg
    Then I had to wait a week to collect the next batch of parts from Wheels Day in Aldershot.
    Essex
    230
    Clarky is offline
    At Wheels Day I collected a few parts from Dukesville and an original '32 wishbone from a chap off NSRA.
    From Dukesville came the '32 steel grill shell, '32 grill insert, Vintique '32 petrol tank and F1 Stainless steel upper shock paints.
    Sadly I did'nt manage to find a '32 front axle and spring so I had to widen my search.
    Over the following week I managed to get the chassis rails cleaned up but I am now waiting for the electrician to arrive so I can fire up my compressor to run my shot blaster as I need that to do the crossmembers.
    Then as if by magic my Chevy T5 gearbox arrived with all the right goodies to connect it up to a Flathead V8.
    While not in the garage I managed to source a 4 piece steel hood, a pair of Lincoln self energising front brakes and a '39/40 rear axle. I had to collect them all from the NASC Swap Meet which was fun in my little car and 3 occupants
    The hood tops were split at each end of the lip that joins them together but after one night in the garage on Sunday and one half has been welded up, the other hlaf will be done tonight.
    That's it for now but I do go out in the garage nearly everynight so be warned there may be alot of updates! For a daily diary/blog check out my site www.thirtieshotrod.com.
    Essex
    230
    Clarky is offline
    Lot's of updates on this one
    I managed to source from a number of people enough parts to assemble a front end, a '32 heavy axle, spring, wishbone and spindles.
    I sand blasted the axle and wishbone, de-chromed the spring and left the spindles as they were already spotless.
    To hang it all together I got a pair of stainless perch bolts and lower shock mounts, a set of '32 king pins, '32 track rod ends, '32 shackle kit, spring clamps and spring u-bolts and clamp. I now had all the parts to start assembling...........
    As I'm trying to build a Traditional looking car I am trying to replace Nylocs with castle nuts etc and Miles a Namco now does these lower shock mount bolts to replace the button head ones that seem to come with most of them.
    As you may remember I was originally going to use Lincoln brakes all round but to speed things up I managed to get a complete front axle running late 40's brakes so I bought that, removed the brakes and then sold the axle and bits.
    Just needed to strip and clean them both before fitting.
    I needed to use the early spindle to hyraulic brake adapters.
    I just couldn't resist fitting the wheels, I know I know!!
    and the front axle as it stands today.......................
    Next update, dismantling the '34 steering box and column for a degrease and freshen up.
    Essex
    230
    Clarky is offline
    I have decided to trial fit absolutely everything once it has been cleaned and once I have a rolling, stopping, starting chassis I will strip it back down and paint in one go.....................
    Rear axle back in with the P&J ladder bars, I won't set this up with the correct angles until the chassis is rolling.
    With the front axle on it's now time to strip the steering box..........
    So I started with a '34 box and column with a 40's cover.
    Then the fun started, soaking bits in degreaser and then running the wire brush over them.
    Only hassle I had was having to remove a bracket off the column so all the remaing parts could be removed, I ended up having to drill the old screws out.
    Quick build up before I stripped it all back down while I wait for a gasket set.
    Now you're all up to date
    I'm waiting for a track rod and the rear brakes to arrive, then I should have some more updates.
    Paint it or Lose it Vonmerkin's Avatar
    Sandy,Beds
    737
    236
    Vonmerkin is offline
    ive been following this on the other site you have the makings of a lovely 40s hot rod there good luck with it some inspiration pics
    Eights For Show, Fours For Go
    Essex
    230
    Clarky is offline
    Cheers for that, the stance of the first pic is just so spot on for what I want to achieve.
    sheffield
    4,207
    1071
    bigjob is offline
    This is a great build,gonna be watchin this one,keep em comin mate ,Bry
    My Intro
    Insurance Repairs, MOT Work
    or Full On Restorations
    Roberts Motor Bodies
    Home of Henry Hirise
    Click to visit our website.
    View the Henry Hirise Re-Build
    Essex
    230
    Clarky is offline
    Thanks Bry, trying me hardest to keep it going, especially as it's my first attempt at a rod
    Had a quick visit to the garage tonight to fit the pedal assembly, after a false start I went in a treat............... well I say a treat until I looked at where the grease nipple goes
    Need to think of a way around this, so before I cut and shut anything I need to get a push rod kit to see what flexibility I have in moving the brake pedal push rod mount.
    Official RnS Addict Kimleonard's Avatar
    Nr Boston, Lincs/ OC. So.Cal
    1,498
    373
    Kimleonard is offline
    I like it, looks like you got some really good parts there to make a trad' rod.
    High tec rods.....elements of the past and the future combining to make something not quite as good as either.
    sheffield
    4,207
    1071
    bigjob is offline
    Clarky,looking at that pic,it might be best to weld/braze the existing hole up and drill and re-tap it where you want it?,you'll need to reem it out of course-just a thought,Bry
    My Intro
There are currently 3 users browsing this thread. (0 members and 3 guests)
    1. 1932 Ford Roadster Brookville (USA) Panels
      Last Post: 12-05-2010, 11:12
    2. 1932 Ford Roadster
      By jamjarjim in forum Vehicles - FOR SALE
      Last Post: 12-09-2009, 09:46
