1937 Rover 10 build
Likes Likes:  70
Page 1 of 18 1 2 3 11 ... LastLast
Results 1 to 10 of 180
    Mar 2010
    Stevenage
    561
    286
    rovertenrod is offline
    1937 Rover 10 build
    Hello Chaps, I thought I'd post a few pics of my long term project. I've had the car for about 5 years but only started working on it again properly around 6 months ago. this is how it looked then
    since then I have sorted the engine
    I then adapted a ZF Tranny
    I have now fitted the pair and fabricated the exhaust fannymoulds
    teesside
    1,244
    139
    MOGG is offline
    like the manifolds
    Mar 2010
    Stevenage
    561
    286
    I have now installed the motor and tranny and fabbed the steering and bulkhead
    and adapted the Toyota alternator
    Mar 2010
    Stevenage
    561
    286
    Thanks
    Quote Originally Posted by moggyroo View Post
    like the manifolds
    Official RnS Addict ifan.miller's Avatar
    Apr 2010
    BRIDGEND, SOUTH WALES
    4,607
    1461
    ifan.miller is offline
    i like that alot motor looks well cool
    Aug 2009
    Hatfield Herts
    193
    214
    oldmanbass is offline
    Love it....need to see more
    Mar 2010
    Stevenage
    561
    286
    Thanks the motor is a 4.5l Daimler majestic major motor. I first saw one in my brothers mates pop in the mid seventies. Had to have one ever since. The car had a pinto in when I got it (too small and don't sound right). Couldn't find a motor sobuilt the car around a SP250 lump (one web site said the motors were almost identical in size - same bore spacing). After a couple of months the right motor came up and you guessed it 3" longer 3"
    Wider and 3" taller ( bugger- it don't fit). Same time I was made redundant and parked the project up (still collecting bits as I could afford). six months ago I finished the garage extension so had no excuse.
    I have run out of money again for a while but I wil still make whatever I can (I'm lucky to have a small mill, lathe, tig, mig etc). I am currently adapting some consul hubs/discs to the firenza front end (I know it's not very trad- but it's what I got) as the viva hubs were converted to 5 stud ford very poorly and my Radirs didn't fit too well. I'm still in the process of adapting the tranny (I need to make a small hub to hold a range rover flexplate 39 mm away Fromm the Daimler flexplate), making a belt tensioner for the water pump and welding and redrilling the water manifold to take a chevy t/stat housing. Then its prop, floor and pedals and away we go.
    I want a painted and finished rod but I also would like to drive it oneday so it might be a little ratty to start....
    Aug 2009
    Hatfield Herts
    193
    214
    I would so love a Daimler in my Austin, like you i want mine painted and finished but ratty it will have to be so i can enjoy it sooner
    Mar 2010
    Stevenage
    561
    286
    Finally got my crank adapter fabricated, Thanks to Trevd. should see some smoke in the next couple of weeks. just need to make up some trans lines and HT leads.
    Mar 2010
    Stevenage
    561
    286
    Had an f***ing nightmare. Wanted to start the engine and listen to the exhaust, first time in 5 years. Cobbled up a throttle linkage and TV connection. Made dipstick tubes and dipsticks. Filled the engine with oil. Filled
    The gearbox- you guessed it - litres of trans fluid on the floor from breather. I only put in 5 litres and supposed to hold 9. And I know I drained it. Fitted the radiator or sieve as its now known- bugger. Jerry rigged a fuel supply and ignition wiring. Low and behold the battery hasn't enough grunt. Oh well! I'm giving up for a while.
    1. pop build up
      By popleea in forum The Garage
      Last Post: 29-09-2012, 11:48
    2. my pop build
      By 1stpop in forum The Garage
      Last Post: 09-08-2012, 21:15
    3. My first engine build - 4.0 Rover V8
      By zephyr in forum The Garage
      Last Post: 19-03-2011, 20:06
    4. rover v8
      By pompeypaul in forum Tech Discussion
      Last Post: 04-05-2009, 17:37
    5. Rover V8 - Offers, Surrey
      By Smithy in forum Stuff - FOR SALE
      Last Post: 24-04-2009, 20:35
