300e Thames - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Thread: 300e Thames
  1. #21
    Apr 2011
    plymouth
    25
    15
    rusto is offline
    Looking forward to following this build . Love 100/300e's , excellent choice of engine . Brilliant stuff !
  3. #22
    Rod'a'holic rodbuilder's Avatar
    Glastonbury
    1,019
    721
    rodbuilder is offline
    Finished off all the welding and have painted the underside with black satin 2 pack. There was some old damage down one side which has been dollied as much as possible and filled over.
    Have filled and primered the rear end so looking quite good now, one of the rear doors needed a new bottom.
    The fuel system on the engine is injection so I need to add a high pressure in tank pump with a swirl pot, I decided to use the original 300e tank and add an internal pump from a 200sx that I had in stock. The seat fuel system does not have a full return flow from the injector rail but uses the external fuel filter to control pressure. This means the injector rail will need to be bled muck like a diesel.
    I will use the original sender unit as I am retaining the gauges.
  4. #23
    I'm a newbie !
    Sep 2013
    Wells Somerset
    5
    4
    Lee malley is offline
    Hi rich. Looking good. Haven't done much on my e. Must find time. See you soon.
  6. #24
    Glastonbury
    1,019
    721
    Now I have finished my sons 32 pick up I have been able to push this forward.
    In order to clear the throttle position sensor, I needed to make a bracket to change the position of the clutch master without cutting the bulkhead. I used a Spitfire one which is at an angle so gives enough space. I fitted a 200sx brake master at the same time to give duel circuit brakes.
    As the engine is transverse mount it has a large aluminium mount on the front which cuts down clearance for the rad so I cut it off and made a blanking plate.
    Filled a number of holes in the bulkhead and sprayed final colour
    After lots of rubbing down for which the next 2 pictures do not convey the time involved I painted the colour on BMW Ice blue from the current Mini
    I will leave this now for a few weeks while the paint settles before colour sanding and giving it a final coat.
    I have a full set of 5 1/2" wheels which I have had blasted and painted body colour but still not sure this is the right choice, I will be fitting chrome hub caps.
    Still need a pair of headlight trims and sidelights if someone can help
    Cheers
    Rich
  7. #25
    Keyboard Worrier Rich G's Avatar
    Somerset
    411
    Rich G is offline
    Did this one get finished Rich? Or is it on the back burner again?
  8. #26
    Glastonbury
    1,019
    721
    It is not yet on the road but apart from sorting the electrics to get the engine running it is just about complete.
    My wife insisted I took care of the ones I have already built and have been using consistantly. I have therefore done the bodywork, interiors and some mechanical issues on the BIVA coupe, A roadster, 34 sedan and the 34 coupe. Along with other jobs on my sons rods and garden projects. Never enough time
    This is how it is at the mo.
  9. #27
    Feckin fibreglass!!
    Aug 2011
    Essex
    463
    Itchy is offline
    That looks lovely!
    If it don't fit, make it adjustable!!!
    1. My Thames 300e van
      By leepop633 in forum The Garage
      Last Post: 13-01-2014, 18:49
    2. interesting 300e thames
      By scottie in forum On Topic
      Last Post: 01-10-2012, 18:55
    3. ford thames 300e van. old skool
      By crumble in forum Vehicles - FOR SALE
      Last Post: 18-08-2010, 18:22
    4. thames 300e
      By jaysrccars in forum Tech Discussion
      Last Post: 24-04-2010, 13:37
