40 Sedan
Results 1 to 10 of 15
Thread: 40 Sedan
    Rods 'n' Sods Junkie neilswheels's Avatar
    chertsey surrey england
    195
    neilswheels is offline
    40 Sedan
    Well, here's my first 40, imported it about 4 yeears ago, had a little work done, realised it was too much work for me and moved it on, I'm pretty sure it's now owned by F-THIS on here.
    Here's a pick of how it was when I imported it, and one when it went.
    195
    And here's my current 40, a lot less work, tho it seems to be taking me a long time to get it back on the road. Hopefully this year, but i've said that before!
    It's gonna be a mild custom/resto to start with, keep the paint, mexican blankets, skirts and caddy caps. Drive it like that for a while, and see what happens.
    For a while, i owned both at the same time...
    gloucestershire
    773
    64
    neil harris is offline
    40 Sedan
    thats my favorite car , still have a model from about 14 years of age .. i will have one i keep telling myself
    Rods 'n' Sods Junkie F-THIS's Avatar
    nelson. lancs
    297
    66
    F-THIS is offline
    ford 40
    very nice you don't have a coupe by any chance.
    [ WINNERS NEVER QUIT AND QUITTERS NEVER WIN.
    195
    No, just the one, that's enough work for me.
    195
    Seeing all the great work going on has 'inspired' me to add an update. So, all suspension has been out, front bones split, bought tci splitter kit, decided i didn't want urathane bushes, so had a new mount made using tierod ends. After a couple of goes at tweaking the spring perches, it looks like it's gonna work.
    Although the car is a deluxe, it came with friction shocks and no anti sway bar. Again, bought a front shock mount kit, but on fitting decided i didn't like the way it worked, so have located some 40 top shock mounts, some 36 perch bolts with a tapered fitting on them, and had some tapered bottom shock mounts knocked up. This is looking much better, basically a copy of the original deluxe 40 stuff that i didn't have.
    Rear end, pancaked the crossmember, twice...school boy error on angles, but i'm over it now. Looking for bottom shock mounts, didn't want to weld brackets to the axle, and had seen the 46-48? ford rear mounts, but we're too much for me at the time. Going thru the bits i had bought for it, i realised that i had two sets of dropped steering arms. The second set has now become my bottom shock mount. The bolt holes are the same front to back, I just moved them thru 90 degrees, knocked up a spacer, had another set of tapered studs knocked up to go in the tie rod eye mounts, and there it is. Still looking at top mounts, either the speedway style stud in the crossmember, or i saw recently an f100 mount bolted horizontally on the inside of the frame rail for a rear mount. Looked good.
    Also been trying to run the exhaust. As I want to drop the W motor in it later, the front half from the flattie is steel, as it will need changing, but from the mufflers back is stainless. Boy what a pain. i'm trying to keep it all up above the chassis, it's tight, and bloody awkward working under the car.Spent 3 hours(one evening) on one bend, trying to get the angle, cutting, tacking, cutting, tacking. Almost got it all connected on one side, then thought I may well want the car lower at some point, so the axle kickup would need to be higher, and the boot floor would have to be raised!! So, that's on going.
    I've got the 'bolt in' adapptor for the dual circuit master cylinder in, and have run all the brakelines, repaired the passenger side floor, made up the drivers side, and a fair few other little jobs, but thats it. Last July other 'stuff' took over, and I only got back in the garage last week. I don't know when it will be out, but i'll keep plugging away..
    gloucestershire
    773
    64
    my dream car !! love em, great thread ...
    you cheif marston and barry houge are all under investigation!!
    Jun 2009
    romford essex
    2,988
    1084
    296moon is online now
    Love 40s but no pics ?
    195
    I cleaned out the garage today....
    12,993
    the first one is now owned by kevpop on here (well, his missus anyway)
    1. 55 sedan delivery help.
      By Plumpcars in forum On Topic
      Last Post: 02-02-2010, 11:35
    2. 32,33,34 coupe,sedan etc.
      By voodoo-daddy in forum Vehicles - WANTED
      Last Post: 26-01-2010, 15:18
    3. Sedan confusion...
      By motor-head in forum Tech Discussion
      Last Post: 25-11-2009, 13:05
    4. 34 sedan
      By goldgasser in forum On Topic
      Last Post: 25-10-2009, 22:04
    5. my ford 40 sedan
      By F-THIS in forum The Garage
      Last Post: 11-05-2009, 21:10
