51 Austin 10cwt Countryman - Page 10
Likes Likes:  8
Page 10 of 10 FirstFirst ... 8 9 10
Results 91 to 97 of 97
  1. #91
    13,381
    mygasser is online now
    it's coming along now, i like it when i can start to bolt bits back on for mockup.
    a point about pics as i've found myself is when you're working on your own sometimes you miss something that becomes clear (to others if not yourself) when you look at a photo. often having a helpful comment can save you some time later on.
    regards, neil.
  3. #92
    Sep 2019
    Nr Malvern, Worcs
    212
    budetta is offline
    Well no one has said its crap yet !!!! Will be attempting to dummy up rear axle for width tomorrow as well , run out of welding gas but get paid Tues so will get a refill . Steering rack mounting will have to be modified but that will have to wait till front suspension is made .
  4. #93
    13,381
    i hope you didn't think i was having a dig, i was just explaining why i'd mentioned pics would be nice a couple of times before. when you commented about people liking pics i thought i'd explain myself.
  6. #94
    Sep 2019
    Nr Malvern, Worcs
    212
    budetta is offline
    Sorry it was just my poor sense of humour , I appreciate any feed back as this is my first major build of a full hot rod /street rod (what ever you call it) . Working on my own it makes it twice as hard getting stuff lined up like the diff , working out chassis ride height and things. I like to see photos of other builds,TBH its made me raise my game looking at the quality shown on these pages.
    One thing I forgot to say was the fact the Austin chassis is not even, the rails differ in shape/section left and right so when adding in crossmembers like rear diff mount the spirit level says fine but theres a good few mm difference where it goes on rails like 4mm . Found gusset on n/s and non on o/s inside rail, tea break special or a Friday one (Austin joke) so have had to triple check it all. Recon its better than stock for alignment now and a lot stiffer.
  7. Likesmygasser liked this post
  8. #95
    Sep 2019
    Nr Malvern, Worcs
    212
    budetta is offline
    Busy on today,engine and box fitted , prop lined up with centre bearing mounted. Front section of prop just cut and tack welded to see how it fits, will get front remade eventually. Chassis at clearing speed bump setting , should lay frame parked up. started to mock up rear De Dion axle . Need to make spacers as its 80mm for axle tube and 90 mm in hub, found a scrap starter motor thats 90mm OD . will strip it tomorrow and check ID . Wish I had a lathe, next is to make a jig to set rear hubs in correct width and alignment then weld it up. Lots to do and I dont have tubing for 4 bar . Talking cost so far it owes me £50 for donor Omega, tenner for steel, tenner for rear wheels and £30 for the Astra Watts linkage
  9. LikesTaxirod liked this post
  10. #96
    Sep 2019
    Nr Malvern, Worcs
    212
    budetta is offline
    Fun and games over for a bit, apparently work have tried (not hard enough in my opinion) to get in touch since last Turs to get me to go back last Sat . My mobile is emergency only as gone past my 2GB limit so not working , strange thought it would take incoming? Any way have to start working again from tomorrow so back to 2 days a week on the rod. Made a jig to hold rear hubs , bolts to inside of drive flange . All shows true so when I fit wheels back on measure between rims will tell me if it worked. Had to cut the axle tube to get correct angle and width, so much cutting that ran out off battery power for cordless angle grinder. The naff corded one I have is giving me grief, cant undo the nut holding disc. Axle tube fits , will have to wait till Sunday to tack it together . BTW the starter motor case was spot on to make spacer ring. Cab section sat back on , worked out ride and rake .
  11. Likeslegendlives liked this post
  12. #97
    Sep 2019
    Nr Malvern, Worcs
    212
    budetta is offline
    Well dear hearts it was going so well and than ran out of MIG gas (knew it would ) but at least axle set up okay. Used a measuring stick to see if track and camber were all parallel, yes it was a stick!! piece of very hard inch square wood and placing it between inner flange on rim its now the same all round.
    Fun getting it right though as set it up and welds kept pulling it a couple of mm out, got it by sticking a screw driver in the cut and careful tacking.
    Watts linkage was a head scratch , cut slot in beam and welded in a off cut piece of 2x2 box with the tube section welded into it . Plug welds at bottom as well. Started to cut sill sections/body mounts and tried on rear arches , loads of fabrication with new rear floor and inner sill to make. Last pic shows ride height under front edge of sill, front valance will be lower.
There are currently 4 users browsing this thread. (2 members and 2 guests)
  1. Dunxster,
  2. Torment
    Last Post: 30-06-2013, 16:31
    Last Post: 16-09-2009, 20:05
    Last Post: 07-08-2009, 09:42
  4. austin front suspension
    Last Post: 06-07-2009, 11:12
  5. 56 austin sayin hi
    Last Post: 20-06-2009, 10:37
