51 Austin 10cwt Countryman - Page 11
Likes Likes:  30
Page 11 of 28 FirstFirst ... 9 10 11 12 13 21 ... LastLast
Results 101 to 110 of 279
  1. #101
    Sep 2019
    Nr Malvern, Worcs
    463
    budetta is online now
    So brave or foolish? moved the B posts back, need to make new inner sill sections though. Finished welding axle , it was tack welded all round and its still moved . Looks like its a ratchet strap and oxy to fix that. Roof will take a bit of working out , the infill has a joint at front and will be "easy " to alter I think .
  2. Likes mygasser, steve1275 liked this post
  3. Remove Advertisements
  4. #102
    Sep 2019
    Nr Malvern, Worcs
    463
    Todays venture, boxed diff mounts then did a lot of pondering . In the end cut floor /inner sill out and made an extra body mounting, roll cage will be going behind B post so will give it something to work off .
    A while back I asked how many beetle steering columns do you need , well the answer is 5 (or 6) as I was looking for mini throttle pedal I found an off cut . Now need tube for 4 bar and its seam less 4mm wall and 22mm dia so dragged them back out of scrap pile . I recon they will be strong enough and will take an 18 mm thread to make adjustable. So todays work in pics
  5. #103
    Sep 2019
    Nr Malvern, Worcs
    463
    Have a bad right wrist after being assaulted, well doing mots shaking wheels and all is not doing it any good. Yesterday afty it went out badly so am now off work . Been told to rest it for a week and go back to Docs , I will be working on Austin then as that doesn't hurt it as wont be twisting it !!!
  6. Remove Advertisements
  7. #104
    Sep 2019
    Nr Malvern, Worcs
    463
    Did some wrist physio today , work out with angle grinder . It does help . Sorted tube for 4 bar then made a start on front suspension, using MGB lower arms . Was going to make tube ones but budget has vanished , lot of cutting again .
  8. #105
    Sep 2019
    Nr Malvern, Worcs
    463
    Bolts and taps turned up so will be able to finish of bars , just need 2 more Vecta spherical joints . Need some more bolts and rose joints for front now, must sell some clocks and stuff I made.
  9. #106
    Sep 2019
    Nr Malvern, Worcs
    463
    Today I feel a bit tapped, cut the threads (18mm) in 2 of the 4 bar links and then the 5/8th ones for upper front wishbone . Chuffed with the weld on link, front suspension just tacked as its a design as it gets made job . Its a bugger not having a lathe , T square and file just dosnt cut it ! and took ages to get the tube ends square. Rose joints ordered for front .
  10. #107
    Sep 2019
    Nr Malvern, Worcs
    463
    Sorted rear axle, ended up with a slice and weld to get tracking right. Put axle in place and set chassis ride height to cruising, that meant making some very short stands to go under frame horns (7in) . Luckily there were 2 knackered ones in scrap pile. Watts linkage sorted, waiting on hole saw to make plates for 4 bar. As you all like pics (and who doesn't) this is rear axle , now there is air bags and dampers to go in there and no room for exhaust.
  11. #108
    13,958
    exhausts are overrated
  12. #109
    Sep 2019
    Nr Malvern, Worcs
    463
    True but I would like to hear the radio on the M way (must be getting old), aiming for a nice rumble . Rose joints and lock nuts turned up, threaded inserts from same place not . My fault did separate orders .
    Tomorrow will fit wheel to front hub and check lower wishbone setting and see what room there might be for air bag, still looks like air bag coil over. Shortest one I have found is to tall though
  13. #110
    13,958
    can't you make the axle brackets drop down from the tube to allow for the long bagovers?
    Last Post: 30-06-2013, 17:31
    Last Post: 16-09-2009, 21:05
    Last Post: 07-08-2009, 10:42
  4. austin front suspension
    Last Post: 06-07-2009, 12:12
  5. 56 austin sayin hi
    Last Post: 20-06-2009, 11:37
