51 Austin 10cwt Countryman - Page 16
Likes Likes:  16
Page 16 of 17 FirstFirst ... 6 14 15 16 17 LastLast
Results 151 to 160 of 164
  1. #151
    Sep 2019
    Nr Malvern, Worcs
    297
    budetta is offline
    Have a bead roller with 5 different formers and a 2ft throat , Flea bay. Got it for noodling the long side repair panel on camper
  3. #152
    Cheltenham
    4,116
    601
    fozwanger is offline
    Quote Originally Posted by budetta View Post
    Well worth the money and makes a neater job too looking good btw
  4. #153
    Sep 2019
    Nr Malvern, Worcs
    297
    budetta is offline
    Cheers, forgot to say the doors I got must be from a later model. Moulding line is not as crisp so shows press tool worn Typical Austin, know a lad that worked on mini line looking after equipment and I said a genuine replacement rear subframe was out of line. They were still using the jig from 59 and it had been repaired many times!!! Even the door height is off by a good few mm but nothing the MIG cant fix.
  6. #154
    13,680
    mini's used to crab going down the road from new, i don't know how they got away with it
  7. #155
    Sep 2019
    Nr Malvern, Worcs
    297
    budetta is offline
    Took door off and welded lower inner frame , ended up slicing it again ----- Made top hinge more adjustable and put packing in lower, still needs some sorting as looks like I need to make lower one adjust out more so door lines up with scuttle . Talking of which I need to repair the lower section as its rusted out.
    Need to shape bottom of door or sill as a bit of fouling going on and the lower rear corner curves in to much so a bit more slicing than I hoped
  8. #156
    Sep 2019
    Nr Malvern, Worcs
    297
    budetta is offline
    Took a day off yesterday, had to sort sick note and see doc . Have another month and going for x ray next week.
    Refreshed I got stuck in, door sorted and fits fine. Getting a bit OCD on shut lines , been watching too many hot rod shows!! Cut gutter off as a bit rusty and need to repair screen pillar/shut as you can see in pic. Door lock fitted and its nearly perfect just a panel thickness deeper, just needs a panel making to give stiffness. Misplaced a box of bits ? cant find rear window mech , did I keep it? god knows but do have front ones .
    Do you think it looks okay gutter less , bit 90s!!but PIA to make new
  9. #157
    Sep 2019
    Nr Malvern, Worcs
    297
    budetta is offline
    Forgot to add , not worked out exterior handle yet. It has to push down on arm and cant use Omega one as first they are yuck looking and second not enough room. Room for window glass to fit past lock , will need some extra channel and inner window surround to match longer doors and one piece windows.
  10. #158
    Milton Keynes
    1,149
    24
    Magman is offline
    I’ve used Jag XJ handles before now and flush mounted them rather than the factory fitting on the surface. It leaves you with a chrome straight handle that sits flush with the door
  11. #159
    Sep 2019
    Nr Malvern, Worcs
    297
    budetta is offline
    Need a dash , looking at an A55 one . Just a question of finding one cut out like the whole section.
  12. #160
    Jun 2011
    bradford west yorkshire
    489
    481
    splitty66 is offline
    Oh how I remember removing rust , keep at it and you’ll be down to the last areas of rust, looks good by the way, liking the longer doors so as to aid easier access , and have you thought of removing the rear side window divider ? ,it might compliment the longer door window.
      Last Post: 30-06-2013, 16:31
      Last Post: 16-09-2009, 20:05
      Last Post: 07-08-2009, 09:42
    4. austin front suspension
      Last Post: 06-07-2009, 11:12
    5. 56 austin sayin hi
      Last Post: 20-06-2009, 10:37
