51 Austin 10cwt Countryman - Page 19
Likes Likes:  18
Page 19 of 21 FirstFirst ... 9 17 18 19 20 21 LastLast
Results 181 to 190 of 202
  1. #181
    Sep 2019
    Nr Malvern, Worcs
    345
    budetta is offline
    Managed to get pics loaded, my metal work station, new rear chassis and tow bar socket. Today fitted the o/s arch and welded it in , starting on n/s tomorrow.
  3. #182
    Rods 'n' Sods Junkie Dan Boy's Avatar
    Jul 2015
    Norfolk UK
    173
    44
    Dan Boy is online now
    How easy is it to use a vice mounted shrinker / stretcher? Mine is a foot pedal type so both hands free.
    If you like choppers you could check out my Facebook page - https://www.facebook.com/KustomChoppersUk
  4. #183
    Jun 2011
    bradford west yorkshire
    499
    481
    splitty66 is offline
    Ooh a Shrinker / stretcher I can only dream, as far as the tow bar , are you going biva and how do you get a tow rating?, Looking good though.
  6. #184
    Sep 2019
    Nr Malvern, Worcs
    345
    budetta is offline
    As it was roded before 88 I think I can get away with it. Yes bit of a bugger holding metal in one hand and operating with the other , saying that could make a pedal as modified my bead roller as it was hard to turn handle when at bottom of turn. Welded an old impact socket to handle fitting , have a broken torque wrench with working ratchet so can keep turning with an easy motion. Need to fit some wheels to stand to move it!!!
    Pics of rear arch , in the pic of rear chassis its not finish yet and will be curved and plated at joint.
    The body sides will be panel glued on .
  7. Likes mygasser liked this post
  8. #185
    Oct 2011
    Southampton
    1,238
    fogey is online now
    Quote :
    'As it was rodded before 88 I think I can get away with it'.
    Interesting turn of phrase . . . . . . . .
  9. #186
    Sep 2019
    Nr Malvern, Worcs
    345
    budetta is offline
    What I should have said was it was originally modified and back on the road in 85 , as I understand it that qualifies it to remain as historic ?
  10. #187
    I'm a newbie !
    Sep 2015
    canterbury
    dave armstrong is offline
    I used a motor drive from and old mobility buggy with a chain and sprocket drive to where the handle attaches, with a foot pedel. Run it through a 12v transformer instead of 24v (which is what they are rated for) and it works fine and travel is at a nice slow controlable speed.
  11. #188
    Sep 2019
    Nr Malvern, Worcs
    345
    budetta is offline
    Well 30000 time I altered the n/s B post position, got it right this time !! Made the header rail . Christened the folder and even managed to do a close double bend , welded it in and door fits spot on. Spot welded the n/s arch panel on, here goes I thought lots of fettling again BUT it fits perfect first time (knock me down with a feather duster!!
    Couple of repair patches to make and then I can fix it in, then I can make inner sill bottom panels and the panels behind rear arches . Battery goes one side and air pump the other.
    have some air connections and thought that will save getting some for air tank, no good as looks like they are BSP? and tank is dash fitting.
    Didnt take any pics of arch just look at previous ones in the mirror!!!
  12. #189
    Sep 2019
    Nr Malvern, Worcs
    345
    budetta is offline
    Did a lot today, repaired arch and managed to get it to fit. Floor support fitted and boxed across the front, not enough 3/4 box but have some roof bars . Oblong section and covered in plastic that just slid off after a slice with blade, its 3 mm 20x 35 ? mm and was perfect to fix original section that goes behind seat that has lip for floor panel (1/2 ins ply) to sit in. Took pic but cant be bothered to load it as well knackered. Looked out of square to me but the stick of inches and spirit of levelness say different .
  13. #190
    13,775
    Quote Originally Posted by budetta View Post
    only if the original rodded parts are still used from what i gather. ie a pop with rover v8, jag irs and viva ifs must keep those basic parts. so if it got a small block chevy, a 9" rear and a drop tube front it is than 'substantially changed'. best to not talk about that stuff on open forums though whether we're right or wrong
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. Spence32
    Last Post: 30-06-2013, 16:31
    Last Post: 16-09-2009, 20:05
    Last Post: 07-08-2009, 09:42
  4. austin front suspension
    Last Post: 06-07-2009, 11:12
  5. 56 austin sayin hi
    Last Post: 20-06-2009, 10:37
