51 Austin 10cwt Countryman - Page 6
Likes Likes:  2
Page 6 of 7 FirstFirst ... 4 5 6 7 LastLast
Results 51 to 60 of 65
  1. #51
    Sep 2019
    Nr Malvern, Worcs
    123
    budetta is offline
    That's OK as the change of name reflects my change of gender, hot rodding/ modifying myself !!!! Cant leave anything as standard.
  2. Likeschaley liked this post
  3. Remove Advertisements
  4. #52
    Sep 2019
    Nr Malvern, Worcs
    123
    budetta is offline
    Off work with a bad toe!!! cant wear steel toe caps. got bored so looking for wheels to fit on the rear and some Saab 95 rims will do. 17ins tri Y ones look good and as they will be hidden by the spats TBH any will do with 235/40s to keep gearing the same for the ABS.
  5. #53
    Sep 2019
    Nr Malvern, Worcs
    123
    budetta is offline
    Watch an episode of Bitchin Rides where they made a single cab pickup cabin 6ins longer. Best bit was they did it the same way I was planning to do mine , roof wont be as easy though as still working that out. Recon it will be cut and see , problem is the infill shape and the fact the rear body is alloy. Looks like I need an AC/DC TIG !!!
  6. Remove Advertisements
  7. #54
    Sep 2019
    Nr Malvern, Worcs
    123
    budetta is offline
    Got a hanging on chest infection so not rubbing down filler and painting parts on the bay panel so looking at the front of the Devon had a plan. AS it will need a bigger rad and the original rad frame takes up a lot of room I have made a frame that goes under front inner wings and runs up the outer side . Its needed as its the support for the front body work . Used the original lower bits that bolt to chassis with a cross bar through that has the uprights that bolt to inner wings attached , well they will be after a whack with the MIG. will take a pic after its welded .Just need to double check its all square first.
  8. #55
    Sep 2019
    Nr Malvern, Worcs
    123
    budetta is offline
    in isolation , still never see anyone down my lock up!!! took some photos of rad mounting. the original frame will be removed leaving a 18 1/2 is x 16 ins hole 3ins deep so should get a decent rad and fan in .
  9. #56
    Sep 2019
    Nr Malvern, Worcs
    123
    budetta is offline
    should have said its not finished yet as depending on rad there might be a mounting welded to bottom bar, top wing brace will be replaced to mount top of rad. can just fit Omega fan and shroud with a bit of bracket (plastic) removal as it is perfect fit between inner wings!!! will have to wait for rad to check depth to engine though. Can fit a pusher fan in front so could go that way .
  10. LikesPop351 liked this post
  11. #57
    9,076
    1772
    blackpopracing is offline
    Both threads now merged for you.
  12. #58
    Sep 2019
    Nr Malvern, Worcs
    123
    budetta is offline
    cheers .
  13. #59
    Sep 2019
    Nr Malvern, Worcs
    123
    budetta is offline
    Can you change name please or can I do it? anyways fitted the frame after a bit of painting just to see if it works. Bolted inner wings in place and it all fits fine, stuck now till panel van finish but that's another thread.
  14. #60
    Sep 2019
    Nr Malvern, Worcs
    123
    budetta is offline
    Got fed up rubbing filler, well tbh waiting for some to harden so took a drill to body side where its riveted to B post just to see how easy it comes off. Some nicely formed ali rivets and the side came free after removing heads. Going to plan !!! there is a frame that roof insert sits in that is riveted to side as well so should be able to remove skin , it will get panel glued back on .Will make it easier to fit/make roll cage as well.
      Last Post: 30-06-2013, 16:31
      Last Post: 16-09-2009, 20:05
      Last Post: 07-08-2009, 09:42
    4. austin front suspension
      Last Post: 06-07-2009, 11:12
    5. 56 austin sayin hi
      Last Post: 20-06-2009, 10:37
