Post Thanks / Like - 5 Likes
Post Thanks / Like - 1 Likes
those fuse holders were common on lorry refrigeration unit switch panels, just in case you need any more.
Closing time pt2.
Another section of the body that's pretty inaccessible are the rear inner roof panels.
I was not sure whether to make a panel and trim it, or weld a panel in and body colour it.
Had a play with some 1mm SS sheet (the other half of the cooker hood that gave it's life for the engine bulkhead) and came up with these:
Here just trial-fitted in place. I figure they will look good in body colour with the headlining (that is the same metallic blue vinyl seen on the trans-tunnel) just tucked behind, or trimmed to the top. So weld it is!
Some time later, stitch-welded in place:
(for any of you that have a 7Y, the bodies aren't the same side-to-side!)
Imagine them in white with the window trims in anthracite grey:
Next, up to the roof which, last time you saw it (if you were paying attention) looked like this:
My main issue with the roof is the roof vent. As I had no access the vent was welded front and rear, then riveted along it's length from the underneath.
Not happy, so I removed the roof support, out with the grinder, then stitch-welded it to the roof along it's length:
Still needs more work, and I need to figure out how the headlining is going to work with the big hole up the middle of it, but I think a plan is hatching!
Post Thanks / Like - 2 Likes
Post Thanks / Like - 3 Likes
Primer suspect....
After a frantic night cutting, grinding and welding as I realised there were a few things more to do before this step, I've actually primed the interior!
Front bulkhead (engine side) and (what's left of the) inner wings:
Looks less like a cooker hood now!
Inside:
All of the original triangular trim-strip holes have now been made round. 'On show' panels have had three coats, bits that will be hidden by trim have had two heavy coats;
As an aside, I decided that my sewing machine really wasn't cutting the mustard so I bought an old Singer industrial machine that has been converted to electric but had seen far better days, but at $60NZ (including a box-load of thread, bobbins, material and spares) I could always weigh it in!.
The original bed was virtually bent double with the weight:
So I've made a longer, double thickness bed out of an old plywood pallet:
I've cleaned and oiled the machine, and adjusted the motor pedal and it goes like the gangbusters!
Double bonus, looking into the history of this machine it appears it was manufactured around the same time as the car.
Stitchin' the Reaper
win on the sewing machine... well done chap .
Originally Posted by
ivanhoew
Pages of clever dimple-died and shaped metalwork, not to mention chucking primer at it and all you're impressed with is the sewing machine?
What's a man got to do....
