Cheating The Reaper - Page 19
Likes Likes:  298
Page 19 of 98 FirstFirst ... 9 17 18 19 20 21 29 69 ... LastLast
Results 181 to 190 of 971
  1. #181
    Feb 2014
    Auckland NZ
    1,102
    2016
    legendlives is offline
    You do seem to be very lucky with all the bargains, fancy looking for a blown 350 chevy for me
    No problem. Shipping might be a bit expensive though......
  3. #182
    Dec 2011
    North Walsham, Norfolk
    205
    justamin is offline
    I'm going to ask my best mate in North Shore to start amassing some bits for when I visit and get married over there - in about 3 years time.....
  4. #183
    Feb 2014
    Auckland NZ
    1,102
    2016
    Quote Originally Posted by justamin View Post
    There are definitely bargains to be had here if you're patient.
  6. #184
    Rods 'n' Sods Junkie NZNick's Avatar
    Jun 2013
    Nelson New Zealand
    436
    967
    NZNick is offline
    Any updates from city of sails?
  7. #185
    Feb 2014
    Auckland NZ
    1,102
    2016
    It's been a while since I updated this, so please bear with me:
    Shortly after my last post I started to build the engine which, upon thorough cleaning, showed a crack down one of the bores. At a time when I was feeling less happy with the build it was the 'last straw'. I felt that the tube frame was too much of a compromise having been built from (at least) 2 different cars, I wasn't happy with the rear suspension, and I wasn't really happy with the VIN-less shell which was always going to be a b*tch to register here. So I put most of it up for sale.
    Fast-forward about a month and this came up for sale:
    It's a 1938 Ford 7Y. Essentially the fore-runner of the Pop, and I've always wanted a Pop.
    $310 changed hands and it was mine!
    Then came decision time - what was I going to build it into.
    Road-legal Gasser was the answer, but this time without too much compromise, so I sat down and designed my own chassis for parallel leaf springs at the front and (possibly) a Jag IRS.
    Here's the making of the main chassis rails so far:
    Front spring rear mounts are double-reinforced:
    Front spring shackles are 5mm steel (as are the rear mounts) with seamless tube spreader:
    Frame material is 40x75x3 steel. All of the gussets are in 3mm steel. The front bush tube is 1"CDS.
    Front axle is a nice aftermarket drop-tube which came with Holden vented discs and 5-stud hubs (all for $100!). Unfortunately it was too wide, so I cut it:
    Sleeved and welded it:
    Then smoothed it all off:
    Fuel tank was found the perfect size at the right price ($100!) so I made the crossmember to fit. This was again from 40x75 box with 3mm gussets. No compromise!
    I'm going to run a fully integrated 8/10 point cage, and have bought the main tube components already, none of the structure from the Escort is being used.
    And that's about where we are at the moment. There's a few other nice bits in the mix as well as a lot of stuff carried over from the Escort.
    Still Cheatin' the Reaper !
  8. #186
    8,949
    1770
    blackpopracing is online now
    310 dollars!!!!!!!!!!! I hate you!! that's amazingly cheap - you would pay more than that just for the grill shell in the UK.
    Chassis work looks spot on so far - nice work.
  9. #187
    Feb 2014
    Auckland NZ
    1,102
    2016
    It's amazingly cheap here too. The previous owner was moving house and had been let down on a few previous 'sales' of the car, so was glad to see it go!
    I've also had a bit of luck with a fibreglass (Pop) front. One of my customers just happened to have one sitting in his garden which he's happy to swap for the original tins.
  10. #188
    Feb 2014
    Auckland NZ
    1,102
    2016
    Managed to find an original Jag IRS in cage for $50. The only problem is it's at least 8 hours drive from here, and couriers/freight won't collect as it's heavy and dirty .
    Looks like I might be having a long day in the van.......
    The main parts of the roll-cage are all bent up now. Just need a few good days to jig the whole lot together and join it up!
    More photos soon.
  11. #189
    Feb 2014
    Auckland NZ
    1,102
    2016
    Just done a deal on the engine. Although I wanted a big-block, one of these came up at the right price ($1k):
    It's a Ford 'Boss 260' engine from an Aussie X8 Falcon. 5.4 litre quad-cam and about as close to a 4-valve hemi as you can get.
    I'm totally stoked with the idea. I'll re-engineer it 'old school' with distributor and carb(s) so I don't have to run 4 miles of wiring and I can actually tune it by ear.....
    Jag IRS arrived yesterday. It's an early XJ6 with a 3.30:1 ratio. Mine for $50! Gotta love NZ
  12. #190
    Feb 2014
    Auckland NZ
    1,102
    2016
    Snotty $50 axle as bought:
    And about an hour later, reduced to the important bits:
    Just have to narrow it by about 225mm per side and it'll be perfect!
    I'll strip & check the CW&P and add a spool whilst I'm at it!
There are currently 6 users browsing this thread. (1 members and 5 guests)
  1. Flip_Front
  1. Brush with the grim reaper
    Last Post: 01-03-2010, 15:46
    Last Post: 27-04-2009, 17:47
  3. the village idiots here
    Last Post: 20-04-2009, 21:42
    Last Post: 20-04-2009, 21:34
