Cheating The Reaper - Page 31
Likes Likes:  224
Page 31 of 89 FirstFirst ... 21 29 30 31 32 33 41 81 ... LastLast
Results 301 to 310 of 881
  1. #301
    Feb 2014
    Auckland NZ
    1,007
    1846
    legendlives is offline
    I thought it was about time I sorted some way of pointing it in the right direction, so here's ther steering part 1:
    Steering box is from a Lada (don't laugh). It's aluminium and well up to the task.
    I made the mount plate some time ago:
    But after positioning it on the chassis it needed to be spaced off by an inch. It would have worked fine without, but this brings the steering column perfectly in line.
    And on the subject of steering column, here is the entirely over-engineered top mount:
    Made from 5mm steel with a 3mm gusset, but it's surprisingly light.....
  3. #302
    Feb 2013
    uranus
    2,094
    ivanhoew is offline
    super spanky metalwork ,as usual .
    Bicester scramble ,Medusa enjoyed the trip.https://www.youtube.com/watch?v=Q-7I7-nA19U
  4. #303
    Feb 2014
    Auckland NZ
    1,007
    1846
    Coming from you that's a real compliment. Thanks dude!
  6. #304
    12,693
    cool column mount , did you make the 'hole' thing yourself
  7. #305
    Feb 2014
    Auckland NZ
    1,007
    1846
  8. #306
    Feb 2014
    Auckland NZ
    1,007
    1846
    More steering goodness:
    The steering column itself is from a Mazda of some sort, and is a collapsible column - essential here in NZ if I have any chance of putting it on the road.
    Indicating duties will be the responsibility of this little on/off/on toggle switch. The two holes in the housing are for LED indicator warning lights (green of course!).
    The unit and tubes are thin-wall steel.
    The additional tube down the column is to keep the wiring hidden and secure. Ends of the tubes are turned down so that I can heat-shrink over the top of them to secure the wiring where it will go along the pivot part.
    And it's grown a quick-release hub. Not sure I'm 100% happy with this, but it will probably look OK once I've removed that ghastly gold colour
  9. #307
    12,693
    does the column need the 'flared' out section at the top just below the quick release hub? if not and the column were the same diameter to the top it would blend/hide the quick release hub much better. keep up the good work
  10. #308
    Feb 2014
    Auckland NZ
    1,007
    1846
    Yes, well spotted. That's why I'm not very happy with it.
    I'll leave it until I've sorted the rest of the controls, then I may weld the splined section directly to the column and make another 'cover tube' for the bottom of the removable hub. Got to keep it neat!
  11. #309
    Feb 2014
    Auckland NZ
    1,007
    1846
    Back in the thread somewhere you'll see the spanky adjustable brake pedal box which I scored (unsurprisingly) cheap.
    Unfortunately, having tried to fit it, it won't - fit that is - without looking hideous, so the only option left to me is to custom-build a pedal box.
    Back when I bought the steering column, it came with a few other parts amongst which was a manual pedal box, so I rescued the pedals and started at them with a drill:
    You'll see the original pivot hole, and the new position for the pivot half-way up.
    Dredging the scrap bin I found a manifold plate that had been cut wrongly (not by me I hasten to add), so managed to cut this:
    and these:
    From the available metal (which incidentally is about 15mm thick aluminium). It's great when you have to design parts around what's available....
    Anyhow, these will all go together like this:
    More as it happens.....
  12. #310
    Feb 2014
    Auckland NZ
    1,007
    1846
    Main plate now suitably prettied up:
    1. Brush with the grim reaper
      Last Post: 01-03-2010, 15:46
      Last Post: 27-04-2009, 17:47
    3. the village idiots here
      Last Post: 20-04-2009, 21:42
      Last Post: 20-04-2009, 21:34
