Cheating The Reaper - Page 42
Likes Likes:  224
Page 42 of 89 FirstFirst ... 32 40 41 42 43 44 52 ... LastLast
Results 411 to 420 of 881
  1. #411
    Feb 2014
    Auckland NZ
    1,007
    1846
    legendlives is offline
    It was ANZAC day here in New Zealand yesterday which is a public holiday. Wifey was working so what better time to wade into another project on the car.
    The fibreglass front is quite old and has had a few modifications (both intentional and non-intentional) over the years. I blocked the grille and side-panel holes after the grille and vents were removed.
    I don't like flip-fronts so decided to make it a two-piece removable front. Out with the grinder and cut more-or-less along the panel lines of the original hood:
    This is the first time that the front bodywork has been mounted accurately in place, and it's nice to see the fit. By this time I'd already cut the front grille opening to the approximate size and shape it will end up.
    The turbos sit under the arches, and have a bit more room around them than I'd estimated:
    And there's loads of room (but a rubbish photo!) under the hood:
    Now this is in place I can get on with mounting the radiator and oil cooler, and sort the fixings for the panelwork.
    A cheeky glimpse under the front skirt:
    About the right stance
    You know your engine is just big enough when.........
  3. #412
    May 2010
    bromsgrove
    689
    49
    steve1275 is offline
    Nuttier than squirrel shit
  4. #413
    Feb 2014
    Auckland NZ
    1,007
    1846
    Now that I have the mounts for the overhead panel in place it's about time I sorted where the switches go:
    Voila! Switches on the left for all the 'legal' stuff (lights, wipers, washers, horn) and on the right for all of the important stuff (Ignition, start, pump1, pump2, fan), and a handy 'ford' badge in case you forget what you're driving.
    Underneath are LED's to show you what's on, along with a voltmeter to show you why it won't crank ( )
    This view shows the shape of the fascia panel. This will probably be polished with the 'box' in body colour.
  6. #414
    Feb 2013
    uranus
    2,094
    ivanhoew is offline
    thats pretty bloody sexy .
    Bicester scramble ,Medusa enjoyed the trip.https://www.youtube.com/watch?v=Q-7I7-nA19U
  7. #415
    woz
    Official RnS Addict woz's Avatar
    Jun 2010
    pulborough, west sussex
    1,330
    394
    woz is offline
    Totally agree very nice work
    I'd luv you if you were the colour of a baboons arse....................
  8. #416
    Feb 2014
    Auckland NZ
    1,007
    1846
    Added a fuse box to the overhead panel.
    This is recessed so that I won't knock them out every time I get in the car, but still easily accessible to the driver.
    Just for the important stuff. The mundane circuits will have fuses in the glove box.
  9. #417
    Feb 2014
    Auckland NZ
    1,007
    1846
    I fitted this quick-release hub to the steering wheel some time ago. I didn't really like it but I hoped it would grow on me. It didn't. It was hideous. It hit me like a carbuncle in my eye every time I looked at it. It could only have been less attractive if Teresa May had been sitting on it. You get the picture....
    So I cut it up, and made this little extension from the QR splines:
    This is internally threaded the same thread as the column, then clearance-bored for the splines, then taper-bored to suit the column taper. This is wound on, then a grubscrew wound into the bottom threaded hole to lock it in place.
    Over the top of that is this spunky column shroud. It's the same OD as the QR hub, and is held in place by the SS cap-head which also serves to show 'straight ahead' on the column (just in case I ever have to put the wheel on in the dark).
    The wheel has also sprouted a small switch panel for the line-lock/roll-control:
    All looks 1,000,000% better than the bolt-on effort.
    What's next?
  10. #418
    nowhere
    6,598
    2288
    nobody is offline
    That panel looks real good. Like the idea of the fuses built in.how did you cut the holes out for them.
  11. #419
    Feb 2014
    Auckland NZ
    1,007
    1846
    They are just oblong holes. Drilled, cut and filed!
  12. #420
    Feb 2014
    Auckland NZ
    1,007
    1846
    Oil cooler mount.
    Take the cooler off and you find this. You have to imagine that the black tube is the front chassis tube and the box section brackets are welded to it.
    The front, smaller diameter tube will be fixed to the front bodywork. the large hook locates over the chassis tube and locks the front end in place.
    To remove the front body, tilt it forwards:
    Then slide it forwards:
    It can then be lifted clear.
    The hooks are in 3mm steel, the brackets are fabricated 40mm x 20mm box in 3mm steel with an extra 3mm reinforcement in the 'slider' hole.
    Now to weld it on in the right place.......
    1. Brush with the grim reaper
      Last Post: 01-03-2010, 15:46
      Last Post: 27-04-2009, 17:47
    3. the village idiots here
      Last Post: 20-04-2009, 21:42
      Last Post: 20-04-2009, 21:34
