Cheating The Reaper - Page 47
Likes Likes:  181
Page 47 of 83 FirstFirst ... 37 45 46 47 48 49 57 ... LastLast
Results 461 to 470 of 827
  1. #461
    8,617
    1752
    blackpopracing is offline
    But if they are not exactly 2:1 you will get drift. If they are 2.01:1 then after 1000 turns they will be .1 of a turn further round. I know you like old school but would it not be easier to use a crank trigger and electonic ignition?
  3. #462
    May 2010
    bromsgrove
    681
    49
    steve1275 is offline
    Er, toothed belts are used to drive camshafts, any 'drift ' would be catastrophic so LL will be just fine with this setup.
    Nuttier than squirrel shit
  4. #463
    12,517
    agreed, that's like saying my 4.11 gears will be 4.56 if i drive long enough. a certain number of teeth will always be that number of teeth
  6. #464
    8,617
    1752
    I disagree Neil, I'm saying your 4.11 gears might be 4.1125.
    I hope it's fine but for timing it add's an unnecessary potential for error.
  7. #465
    Feckin fibreglass!!
    Aug 2011
    Essex
    463
    Itchy is offline
    Thats what I was thinking!
    If it don't fit, make it adjustable!!!
  8. #466
    Jul 2010
    garden of England
    513
    27
    thisYup is offline
    sorry Blackpop, you're wrong on this one! 4:11 gears will always be 4:11, wear will cause backlash, but won't change the ratio
    my boss' hart 420 r race engine has a cogged belt driving the cam train like many, many other engines, and another cogged belt from cam to dizzy.. it's a 9000rpm engine, so cam timing is pretty critical considering the valves overlap in the head!
    the cogged belts are otherwise known as timing belts in industry
    20 teeth on one to a 10 tooth one via a tooth belt will always be 2:1 until the cogs rot or the belts snap!...
    there's probably more backlash in a conventional dizzy gear drive off the cam, than there is with a toothed belt drive off the crank!
  9. #467
    12,517
    it might be 4.1125, but it will always be 4.1125. the number of teeth on each gear can't change (unless they break).
  10. #468
    Feb 2014
    Auckland NZ
    945
    1702
    legendlives is offline
    Blimey, I didn't mean to start WW3!
    Blackpopracing you're right, I could just use a crank trigger with the associated electrical gubbins, but it wouldn't be half as cool!
    There is a budget issue as well. I'm trying to make everything I can to keep the price down. So far I've only spent $4000NZ (about 2K GBP) on the entire build including purchase of the car. New crank trigger etc would probably add 50% to that number.
    Oh, and as far as the belt drive is concerned its 2:1. It came (as I may have mentioned) from driving a balance shaft on a Mitsubishi engine. I'm sure most Mitsi drivers would be sorely ****ed if their engines went progressively out of balance......
  11. #469
    Rods 'n' Sods Junkie 69 ford's Avatar
    Sep 2009
    East Yorkshire
    284
    14
    69 ford is offline
    Belt drive/cogged belt it is then!
  12. #470
    Feb 2014
    Auckland NZ
    945
    1702
    Carb tried in place:
    Hmm. May have to rethink the bonnet bulge!
    Also took out these annoying panels that were originally there for the bonnet catches. I'm not using bonnet catches......
    I also ended up with hairy hands. Either I've been fingering a sasquatch or it's fibreglass time!
    Aah. Must be fibreglass time. New sexy front-end brackets glassed in place. I'll take out the screws and fill the holes once it's fully set:
    1. Brush with the grim reaper
      Last Post: 01-03-2010, 15:46
      Last Post: 27-04-2009, 17:47
    3. the village idiots here
      Last Post: 20-04-2009, 21:42
      Last Post: 20-04-2009, 21:34
