chop top mk2 - Page 175
Likes Likes:  84
Page 175 of 203 FirstFirst ... 75 125 165 173 174 175 176 177 185 ... LastLast
Results 1,741 to 1,750 of 2023
Thread: chop top mk2
  1. #1741
    May 2012
    lancashire
    1,228
    2208
    chop top mk2 is offline
    running new gauges so i guess there not matched.
    one thing i have changed is the coolant, it had a very weak mix with antifreeze but now has the proper amount in. been told that will help cool it a little. dont know if thats true or not.
    i took the stat out as i was not sure it was working, thought it would not effect the running temp.
  3. #1742
    13,278
    have you any way of accurately checking the temp'? i had a big block fairlane a few years back, always ran a bit on the hot side. i did all sorts and eventually stumped up for a massive ally rad from sercks. still the same. got a digital probe and the gauge was reading hotter than the engine actually was. the rad looked pretty though.......
    re the stat, without it the coolant can flow though the rad' too fast so isn't in there long enough for the rad' to do it's job transferring heat to the air flowing through it. maybe fit a 'stat with the middle cut out so it 'thinks' the 'stat is open all the time but slows the flow a bit.
  4. #1743
    Rods 'n' Sods Junkie 69 ford's Avatar
    Sep 2009
    East Yorkshire
    357
    18
    69 ford is offline
    Needs to be road tested for an accurate assessment of running temperature, ie load on the engine will create more heat and airflow will reduce heat etc. also consider the rad cap pressure rating.
  6. #1744
    May 2012
    lancashire
    1,228
    2208
    cheers guys for the advice it,s much appreciated,
    i think the rad is to small. its a sierra cosworth one with a 50mm core. going to order a bigger rad and as you say mygasser put a stat back in and i hope that will sort the problem.
  7. #1745
    Rods 'n' Sods Junkie NZNick's Avatar
    Jun 2013
    Nelson New Zealand
    436
    967
    NZNick is offline
    Brilliant car and attention to detail
    Another point to consider is somewhere for the air that's gone through the radiator into the engine bay to escape from.
    You need a space (or spaces) the same as the area of rad, so air in = air out, so no pressure build up under the bonnet which would reduce airflow through the rad.
  8. #1746
    May 2012
    lancashire
    1,228
    2208
    cheers NZNick, glad you like it.
    mate of mine today said that if i run pure green antifreeze it would help lower engine temp, anyone tried it. he also said that as the engine has been rebuilt with new bits its bound to run a little hot untill it beds itself in.
    just had a full 3 days on it and have made alot of progress, dash is now in and wired, windows all fitted.
    few pics from today
  9. #1747
    9,162
    1774
    blackpopracing is offline
    Pure antifreeze wont help - it will make it worse.
    antifreeze helps engines run cooler but only at the recommended mix (I forget but its about max 50% water 50% antifreeze). You need to run a stat, no drilling holes or removing the middles - just a proper stat. You can get different temperature ones so its worth looking up what the factory ones are first and possibly picking one a little lower in temp.
    New engines are usually tight and will run a little hotter, but if you have a infra red thermal reader see what the radiator is actually reading.
  10. #1748
    Sep 2009
    East Yorkshire
    357
    18
    69 ford is offline
    I don't run a thermostat in my Cortina as I have an electric water pump i.e. as soon as the engine reaches temperature turn the pump on, If it starts to get above 140 then turn the fan on, works fine. This also allows me to rapidly cool the motor between rounds by leaving the pump and fan running for a few minutes with the engine off, when it was on the road I had a VW Sirrocco ally rad and thermostat fitted which worked ok but I did cut some vents in the bonnet to improve airflow which improved things.
    Its all trial and error really.
  11. #1749
    Jun 2013
    Nelson New Zealand
    436
    967
    NZNick is offline
    You could always try a 'water wetter' like redline coolant additive, Demon Tweeks do it
  12. #1750
    May 2012
    lancashire
    1,228
    2208
    never even heard of 'water wetter' just ordered some. cheers NZNick,
    you never know it might just help.
There are currently 3 users browsing this thread. (1 members and 2 guests)
  1. RDB
  1. Mk2 Zodiac Dash Top
    Last Post: 25-03-2010, 20:59
  2. chop saw/ w/shop heater
    Last Post: 31-07-2009, 04:57
  3. mk2 consul bits
    Last Post: 08-05-2009, 20:30
  4. zodiac mk2
    Last Post: 30-04-2009, 19:43
  5. Transit MK2 steering box
    Last Post: 28-04-2009, 20:54
