chop top mk2 - Page 176
Likes Likes:  76
Page 176 of 200 FirstFirst ... 76 126 166 174 175 176 177 178 186 ... LastLast
Results 1,751 to 1,760 of 1999
Thread: chop top mk2
  1. #1751
    9,081
    1772
    blackpopracing is offline
    Before you waste the money you spent on it by draining it out again I would research why it runs hot (if it actually is running hot).
    You need to find out the real temperature it's running at first then find out why (if it is too hot).
  3. #1752
    Official RnS Addict digger's Avatar
    Jun 2009
    near ipswich
    3,404
    2784
    digger is offline
    I use water wetter in my T and it works.
  4. #1753
    13,151
    I 've used water wetter too, good stuff. Definitely check the ACTUAL temp' the engine is running at before you go any further though. You must be able to borrow a digital probe from a local garage or friend.
  6. #1754
    Rods 'n' Sods Junkie alan's Avatar
    Billericay
    336
    15
    alan is offline
    Agree with Blackpop, that rad should be fine, its all about the amount of air passing through the radiator , taking the heat away.
    I have a 351 cleveland in a sierra and a sierra rad with the original shroud and twin fans, never had issues even in the heat and heavy traffic at Le Mans.
    Just found a pic of your rad.
    Ideally you want the fans to pull air through the whole surface of the radiator not just two circles, and as you have those cut outs in the support framework, that is also reduced the efficiency of the fans.
    Check out a production unit, the fan cowl is fitted tight to the surface of the rad so all the air the fan is pulling comes through the radiator.
    Also have you got the radiator sealed to the front panel so when you are moving forward, all the air that goes in the grill is funneled into the rad, ?
    all teething issues, easily sorted.
  7. #1755
    Herts
    4,617
    224
    WB54 is offline
    two things I'd look at 1, base timing, retarded timing builds a lot of heat, vac advance helps. 2, water flow, been mentioned on here, the wrong mix of coolant won't transfer heat and being pumped too fast either by a wrong size pulley or electric pump will throw it round without heat transfer. You need the restriction of the stat or a restrictor plate under the pump water passages.
    The point around fan shroud is also a good point, the fan needs to draw heat off the entire surface and the fan should be sealed to the rad.
  8. #1756
    Rods 'n' Sods Junkie mike t's Avatar
    Apr 2010
    bristol england
    307
    50
    mike t is offline
    Just a point to mention if you use more than the recommended anti freeze to water ratio which is normally 50/50 the coolant could freeze.
    In very cold weather.
    I know that sounds weird but very true so using all anti freeze and no water is a no no.
  9. #1757
    May 2012
    lancashire
    1,214
    2195
    chop top mk2 is offline
    thanks for all the advice, been through the way the rad is set up, the fans cover nearly the whole rad as they are. i have added an expansion tank to the rad and plumbed it into the bottom radiator hose so it now holds another 2 litres of coolant ( which is just blue antifreeze with a 50/50 mix ) and of course the wetter water stuff, just waiting for a couple of bits to land this week then i can see if its any better.
    got the car outside today to see how it looks, you cant really see the roof chop inside but out side it looks sick,
  10. #1758
    May 2012
    lancashire
    1,214
    2195
    heres those pic,s
  11. #1759
    Rods 'n' Sods Junkie 69 ford's Avatar
    Sep 2009
    East Yorkshire
    348
    18
    69 ford is offline
    The wheels/colour combo works really well, bet you're itchin to take it for a spin!
  12. #1760
    Official RnS Addict markyb37's Avatar
    Oct 2011
    christchurch , dorset
    619
    1178
    markyb37 is offline
    Hi Tony,hope you're well.Just caught up with your progress.................absolutely fantastic .Not sure if its possible ,but she looks even better outside .Keep up the great work .Speak soon.Mark.
    1. Mk2 Zodiac Dash Top
      Last Post: 25-03-2010, 20:59
    2. chop saw/ w/shop heater
      Last Post: 31-07-2009, 04:57
    3. mk2 consul bits
      Last Post: 08-05-2009, 20:30
    4. zodiac mk2
      Last Post: 30-04-2009, 19:43
    5. Transit MK2 steering box
      Last Post: 28-04-2009, 20:54
