chop top mk2 - Page 197
Likes Likes:  63
Page 197 of 198 FirstFirst ... 97 147 187 195 196 197 198 LastLast
Results 1,961 to 1,970 of 1977
Thread: chop top mk2
  1. #1961
    May 2012
    lancashire
    1,189
    2159
    chop top mk2 is offline
    back on the tina,
    with all the ignition problems sorted ( hopefully ) its time to sort the other big problem, the gearbox.
    ever since i built the car the gearbox has been a reel pain so its out with the old and in with the new. the new being a mazda rx 8 5 speed, i have made the adaptor plate and i have a rover flywheel at the machine shop being machined to fit the rx 8 ring gear.
    now because the car was built around the old gear box its not going to be easy to do the swap so today i started cutting the old gearbox mount out and fabricated a new one . with that done the chassis rail was next, its were the starter motor wants to be so i have made a new section up and welded it in. im just hoping i dont have to remove any of the floor.
    i will get some pics on tomorrow.
  3. #1962
    Sep 2019
    Nr Malvern, Worcs
    50
    budetta is offline
    Never simple -----------
  4. #1963
    Now a BIVA Build dlonamow(oldwoman)'s Avatar
    Nov 2010
    bromsgrove
    910
    886
    dlonamow(oldwoman) is offline
    yay
  6. #1964
    May 2012
    lancashire
    1,189
    2159
    the floor sections that wanted tweaking are now all done and all the new parts arrived just before xmas.
    new pedal box,
    an exedy 6 speed clutch kit,
    also the flywheel has been machined,
    i am using a 6 speed clutch assy even though i only have a 5 speed box because the clutch diameter is bigger.
    i made a bracket the other day to mount the new pedal box in to the foot well,
    i have changed the fixing points from 6mm to 8mm.
    i have changed the pedal box because with everything under the dash it was a real pain to work on, so now with the new set up it will be very easy to service.
  7. #1965
    Rods 'n' Sods Junkie 69 ford's Avatar
    Sep 2009
    East Yorkshire
    328
    18
    69 ford is offline
    If Carlsberg made pedal boxes... £££ great work.
  8. #1966
    Dec 2010
    Near Canning Town, London
    1,744
    1806
    Taxirod is offline
    This build was so epic, I always felt that the gearbox was the weak point, glad you are getting it sorted now.
    I'm hoping to use a RX8 6 speed behind my Zetec so will watch with interest.
    Pedal box looks great, hmm, bet it wasn't cheap though!
  9. #1967
    May 2012
    lancashire
    1,189
    2159
    cheers ian,
    your right when it comes to the box its never really been any good. pedal box was not to bad really price wise £395 all in.
    the pedal box is now all mounted to the floor and all the brake pipes are done. i have put the rx8 gearbox onto the cortina.s engine and put it back in so i can weld on the mounts as i need to move the hand brake back a little as the new box is a little longer.
    more soon.
  10. LikesTorment, 55zephyr liked this post
  11. #1968
    12,883
    re the pedal box, we do one like that at work but much cheaper at £237.12 inc' vat https://www.rallydesign.co.uk/produc...ducts_id=24101
  12. #1969
    May 2012
    lancashire
    1,189
    2159
    got a bit more done,
    i have had to move the handbrake back abit because of the new gear stick position which turned out to be alot easier than i thought. with that and the box in it as a knock on effect and that is the trans tunnel cover panel, it now does not fit.
    so its out with the sheet metal and the bead roller to make a new one. this time how ever i am going to make it in 3 pieces as the old one was a pain to remove.
  13. Likesblackpopracing liked this post
  14. #1970
    May 2012
    lancashire
    1,189
    2159
    bit more done.
    made up the next piece ,
    over the last few years the garage seems to get really cold (or i could just being getting old ) so over the last few months we have been installing a fire with a back boiler so later on we could plumb in a few radiators. today was the day when we could finally fire it up.
    what a difference , its going to make working in winter alot better.
  15. Likesblackpopracing liked this post
    1. Mk2 Zodiac Dash Top
      Last Post: 25-03-2010, 21:59
    2. chop saw/ w/shop heater
      Last Post: 31-07-2009, 05:57
    3. mk2 consul bits
      Last Post: 08-05-2009, 21:30
    4. zodiac mk2
      Last Post: 30-04-2009, 20:43
    5. Transit MK2 steering box
      Last Post: 28-04-2009, 21:54
