chop top mk2 - Page 203
Likes Likes:  87
Page 203 of 206 FirstFirst ... 103 153 193 201 202 203 204 205 ... LastLast
Results 2,021 to 2,030 of 2051
Thread: chop top mk2
  1. #2021
    13,413
    that's a lot of jobs completed in 1 day, well done.
  3. #2022
    May 2012
    lancashire
    1,250
    2211
    chop top mk2 is offline
    cheers neil,
    i think i have bigger problems, the fitech is not reading the rpm signal so after 5 mins of running engine just cuts out. it will restart but wont run. i have contacted steve where i got the fitech from and this weekend i will try a couple of things he has advised and i am hoping that will sort the problem.
    was making some reel progress , bit gutted to be honest .
  4. #2023
    9,188
    1774
    blackpopracing is offline
    Fitech supplied sensors are reputedly rubbish. Changing them out for GM ones can often fix the issues.
  6. #2024
    May 2012
    lancashire
    1,250
    2211
    problem not sorted. it does not have any error codes but it will tick over for a bit then the rev,s go up to 1700 rpm then the engine stops.
    i dont know enough about them blackpopracing to start messing. i will ring steve again on monday and see what he says and take it from there.
  7. #2025
    May 2015
    Birmingham
    391
    2
    drseg is offline
    a long shot that I came across on a k series rover that was still under warranty, would drive fine then suddenly run rougher and rougher till stopped dealer failed to find anything and it usually didn't play up was a mates wifes so after I'd experienced it, turned it off left a few secs and restarted running perfectly for a couple of minutes decided to check timing was ok and then suddenly as it misfired and spluttered and stopped, retarded retarded and retarded till it stopped, did it again and again looked under the exhaust manifold a loose nut on a support bracket rattling causing the anti knock sensor to retard the ignition till i9t wouldn't run and the rougher it ran the more it rattled and the more it retarded tightened it and problem disappeared, probably not but worth a quick check for anything loose
  8. #2026
    9,188
    1774
    I've heard plenty of bad reports about Fitech, this is just another in a long list of them.
    Check the crank sensor - this is one of the most common issues.
  9. #2027
    May 2012
    lancashire
    1,250
    2211
    total no start today, i know this sounds stupid but its like it now has no rpm signal at all its like the wire has broke. i am going to check that wire with a meter on tuesday to see if there is any current running through it.
    i will ring steve tomorrow to see what he say,s and then go from there.
  10. #2028
    Feb 2013
    uranus
    2,330
    ivanhoew is offline
    if its a 2 wire sensor try swapping the wires over .
  11. #2029
    May 2012
    lancashire
    1,250
    2211
    its been a slow process but i think we might have solved the problem, i hope.
    the fitech all seems to work ok so it does not look like its fried its brain, it looks more like the throttle position sensors so steve has put two in the post and i should have them tomorrow.
    since the car came back from a show last year ( heavy rain all day and the bonnet of most of the time ) the car has had a very lumpy idle and i mean lumpy and it had got worse up to the point of the car not starting. the rpm would on tick over go up and down some 300/500 rpm and then towards the end the rpm would rise to about 1700 and then just die so may be that was the sensor giving up the ghost .
  12. #2030
    May 2012
    lancashire
    1,250
    2211
    parts have arrived,
    steve has sent out 2 throttle position sensors so tomorrow will see if it solves the problem.
    1. Mk2 Zodiac Dash Top
      Last Post: 25-03-2010, 20:59
    2. chop saw/ w/shop heater
      Last Post: 31-07-2009, 04:57
    3. mk2 consul bits
      Last Post: 08-05-2009, 20:30
    4. zodiac mk2
      Last Post: 30-04-2009, 19:43
    5. Transit MK2 steering box
      Last Post: 28-04-2009, 20:54
