chop top mk2 - Page 48
Likes Likes:  100
Page 48 of 209 FirstFirst ... 38 46 47 48 49 50 58 98 148 ... LastLast
Results 471 to 480 of 2090
Thread: chop top mk2
  1. #471
    Rods 'n' Sods Junkie gibber's Avatar
    Aug 2012
    G-Style Speedshop
    275
    7
    gibber is offline
    That exhaust looks freakin awesome!
    See what goes on in my garage https://www.rodsnsods.co.uk/forum/gar...eed-shop-66587
    or my facebook page for the VW's as well http://www.facebook.com/GStyleSpeedShop
  3. #472
    Oct 2013
    Southwater, West Sussex.
    26
    Zoompod is offline
    Wow, I said earlier in the thread that this style wasn't my cup of tea, you've changed that old son. Really can't wait to see this finished.
  4. #473
    Sep 2009
    anglesey
    83
    redhouse53 is offline
    Amazing work, i’ve learnt a lot from this thread, thanks
  6. #474
    May 2012
    lancashire
    1,268
    2221
    chop top mk2 is offline
    cheers for the comments its much appreciated.
    started to sort the rack as has been said on here it would split apart if used. had some back bits lazor cut when all the bits were made.made up this c clip up
    it locates on a lug on the alloy part of the body.
    fits in like this
    and when its welded in place,
    should hold it all together. also started to fab the radiator brackets, drilled them just need to cut them out tomorrow at work, polish and then weld them up on sunday. more then
  7. #475
    May 2012
    lancashire
    1,268
    2221
    try again.
  8. #476
    May 2012
    lancashire
    1,268
    2221
    got the rack all done , lot more solid now.
    also cut the rad brackets and pre polished them on the inside before welding them.
    get them polished on the outside now before welding them to the rad.
    couple of pics of the down pipefrom the turbo,
    tight fit but all fits ok. more tuesday
  9. #477
    I'm a newbie !
    Dec 2013
    Newport
    6
    Bluebird102 is offline
    Great fabrication skills you have its looking very very good.
    The tig welder your using what do you think of it ?
    is it easy to use and reliable, i know for the money they are that it seems you cant complain to much,
    any info on how you rate would be great.
  10. #478
    Official RnS Addict markyb37's Avatar
    Oct 2011
    christchurch , dorset
    620
    1203
    markyb37 is offline
    A great project , great skills .Keep those pics coming .Part of me wants to see this project finished and part of me just wants see MORE fabrication !!!!!!
  11. #479
    Rods 'n' Sods Junkie crewchief's Avatar
    Sep 2009
    warrington
    221
    24
    2
    crewchief is offline
    Hi chop top if you look under most modern cars they have heat panels where the exhaust runs .im using it on my model a because i am routing my exhaust system in the pod where the running boards are and the silencers will be quite hot under there.its impregnated ally sheet so you can easily shape it .glyn
  12. #480
    May 2012
    lancashire
    1,268
    2221
    thanks for the comments guys,
    tig welder is really not that bad, for 350 quid you get what you pay for . been messing with the pulse setting on it tonight welding up some 5mm ally strip and it does not a bad job. i would give it a 7 for ease at which it is to set up and use. best 350 quid i have ever spent any way. cheers glyn for the nod towards the heat shied , will look into it.
    got the bottom mounts for the rad done tonight.
    seems to be plenty of room for the fans.
    its going to get a bit tight for room in front of the rad as there is still coolant hoses and inter cooler pipes to run.the offy carb manifold inlet housing points the wrong way
    and with a coolant hose on would foul the dizzy so modded a rover one which points in the wright direction
    where does the pipe go to on the bottom of offy intake housing and if i blank it can i use the sender unit mount as a return as there is a sender in the rover houising.
    any help would be much appreciated .more sunday.
    1. Mk2 Zodiac Dash Top
      Last Post: 25-03-2010, 20:59
    2. chop saw/ w/shop heater
      Last Post: 31-07-2009, 04:57
    3. mk2 consul bits
      Last Post: 08-05-2009, 20:30
    4. zodiac mk2
      Last Post: 30-04-2009, 19:43
    5. Transit MK2 steering box
      Last Post: 28-04-2009, 20:54
