chop top mk2 - Page 49
Likes Likes:  71
Page 49 of 200 FirstFirst ... 39 47 48 49 50 51 59 99 149 ... LastLast
Results 481 to 490 of 1993
Thread: chop top mk2
  1. #481
    Jul 2009
    Yeovil, Somerset
    1,762
    822
    Stroprock is offline
    Quote Originally Posted by chop top mk2 View Post
    Bottom pipe should be the thermostat bypass so you've always got some coolant circulating even before the stats open. Should be Ok to use the sender outlet. Only concern might be no.2 cylnder might run cooler than no.1 I guess, becuase the bypass isn't in the middle anymore.
  3. #482
    May 2012
    lancashire
    1,201
    2179
    chop top mk2 is offline
    thanks for the advice stroprock,
    little bit more done today. the alternator was one of the parts that was never going to fit with the exhaust manifolds and extreme tight fit of the engine in the chassis so having to make a custom bracket to hold it in position. using the bolt locations on the left side of the engine came up with this.
    it will need spacing of the engine
    get the parts cut through the week, all so bit more on the intack pipe. this needs to be rubber mounted to the slam panel.
    few bits on order, oil cooler, remote oil filter block and some 3" alloy tube so i can get the inter cooler all mounted. more soon
  4. #483
    May 2012
    lancashire
    1,201
    2179
    few more bits landed this week.
    oil cooler, oil filter block, 3"" alloy bends for the intack and some silicon hose. theres still a few bits to come this week.
    sorted the alternator bracket today just wants polishing before i weld it up.
    also started to build a scoop to draw fresh air from the front grill opening to cool the oil cooler , made it from some 1.5mm sheet alloy.
    this mounts under the head lamp on the drivers side
    not getting as much time on it as i would like but hoping things will change in the next couple of weeks. more soon
  6. #484
    Now a BIVA Build dlonamow(oldwoman)'s Avatar
    Nov 2010
    bromsgrove
    910
    886
    dlonamow(oldwoman) is offline
    keep on posting, then i can pinch more of your ideas
  7. #485
    8,957
    1770
    blackpopracing is online now
    Nice to see updates
  8. #486
    12,984
    neat oil cooler ducting.
  9. #487
    Jul 2009
    Yeovil, Somerset
    1,762
    822
    Love your welding, that alternator bracket puts mine (puts most in fact) to shame
    Amazing build, keep us updated!!
  10. #488
    I'm a newbie !
    Dec 2013
    Newport
    2
    Bluebird102 is offline
    Top notch design,fabrication and quality mate, can I ask what Tig welder you are using on your ally ?
  11. #489
    May 2012
    lancashire
    1,201
    2179
    thanks for the comments ,
    the tig welder is only a cheap one 350 quid but it does a good job on ally.
  12. #490
    May 2012
    lancashire
    1,201
    2179
    bit more done on the oil cooler scoop.
    also got the hole drilled to feed it.
    more sunday
    1. Mk2 Zodiac Dash Top
      Last Post: 25-03-2010, 20:59
    2. chop saw/ w/shop heater
      Last Post: 31-07-2009, 04:57
    3. mk2 consul bits
      Last Post: 08-05-2009, 20:30
    4. zodiac mk2
      Last Post: 30-04-2009, 19:43
    5. Transit MK2 steering box
      Last Post: 28-04-2009, 20:54
