chop top mk2 - Page 51
Likes Likes:  87
Page 51 of 205 FirstFirst ... 41 49 50 51 52 53 61 101 151 ... LastLast
Results 501 to 510 of 2049
Thread: chop top mk2
  1. #501
    May 2012
    lancashire
    1,248
    2211
    chop top mk2 is offline
    bit of a question for you . car is hard to push forward but when jacked up the wheels turn freely . but when both wheels are run forwards they are hard to turn. is this normal for this jag rear end or is there something wrong( have noticed it has been leaking oil) any help would be much appreciated . body is back off to sort the rear hubs as the bearings have gone on the drivers side and to set all the coilovers so car sits at the correct ride height and the frame wants drilling so the exhaust can come out through the back of the sill. more at the weekend
  3. #502
    Glasgow,Scotland
    2,123
    german8rcoupe is offline
    Is it a Powerlock?
  4. #503
    May 2012
    lancashire
    1,248
    2211
    no its not.???????????? when you turn one wheel clockwise the other wheel spins the other way.
  6. #504
    Rods 'n' Sods Junkie alan's Avatar
    Billericay
    342
    15
    alan is offline
    Is the prop on and in gear?
  7. #505
    Rods 'n' Sods Junkie Grumpy Grandad's Avatar
    Dec 2012
    South
    469
    37
    Grumpy Grandad is offline
    Sorry to hear of your troubles, after all the work you've put into this build the last thing you want is fixing it instead of driving it. If this is any help , jack up the rear end and rotate both rear wheels at the same time as if the car was moving forward with the prop disconnected. If it's still hard to turn look at the diff , if it's easy the look at the gearbox.
    Steve
  8. #506
    May 2012
    lancashire
    1,248
    2211
    had it jacked up and spinning both rear wheels forward its still hard to turn but runs freely when wheels are rotated backwards. prop is not connected so i guess it must be the diff.
  9. #507
    Dec 2012
    South
    469
    37
    Sounds like it could be the diff, but just to make sure, are you certain the brake pads are not binding ( moving) when the wheel moves in the forward direction and returns when the wheel moves in the other direction?
    Just a thought, hope you find it.
    Steve
    Steve
  10. #508
    May 2012
    lancashire
    1,248
    2211
    i m sure its the diff but got another jag rear axle so im just going to swap the diff on sunday and then i will know for sure.
    thanks any way grumpy,
  11. #509
    Glasgow,Scotland
    2,123
    The crown wheel and pinion are a matched set so do you mean you are changing the whole centre section or just the CW?
  12. #510
    May 2012
    lancashire
    1,248
    2211
    sorry meant the whole thing for another unit.
    got some more tubes welded into the cage. now i know there not going to get in the way made sense to put them in after all the main parts were bolted on.
    also managed to get the rear drive shaft loop done.
    and started putting the holes in the side of the frame so the exhaust will come out the sill. will weld up the holes in the rear of the frame.
    more tomorrow.
There are currently 4 users browsing this thread. (0 members and 4 guests)
    1. Mk2 Zodiac Dash Top
      Last Post: 25-03-2010, 20:59
    2. chop saw/ w/shop heater
      Last Post: 31-07-2009, 04:57
    3. mk2 consul bits
      Last Post: 08-05-2009, 20:30
    4. zodiac mk2
      Last Post: 30-04-2009, 19:43
    5. Transit MK2 steering box
      Last Post: 28-04-2009, 20:54
