chop top mk2 - Page 53
Likes Likes:  87
Page 53 of 206 FirstFirst ... 3 43 51 52 53 54 55 63 103 153 ... LastLast
Results 521 to 530 of 2053
Thread: chop top mk2
  1. #521
    May 2012
    lancashire
    1,251
    2214
    chop top mk2 is offline
    bit annoying just waiting for bits to come . the wheels and other bits are going to be a couple more weeks so thought i would get the shourd sorted to hold the fans in place. draw this up the other day so they can be lazor cut
    this weekend going to start sorting the body out so it can go for blasting before it,s welded to the frame. more soon
  3. #522
    Now a BIVA Build dlonamow(oldwoman)'s Avatar
    Nov 2010
    bromsgrove
    910
    886
    dlonamow(oldwoman) is offline
    going to make my fan shroud thingy didn't like to look of those cable tie things stuffed through the vains
    thanks for the tip got almost the same rad as yours
    i will drill cut and file i'm to tight to pay for lazor
  4. #523
    May 2012
    lancashire
    1,251
    2214
    i know what you mean about the about the cable tie things, ive made some little alloy blocks which bolt to the fans ( in the slots) to hold them together and then the shroud will bolt to the blocks. should look ok when all bolted up.if it works
  6. #524
    Glasgow,Scotland
    2,123
    german8rcoupe is offline
    Does the shell need blasted? It could be the worst thing you do to it! Unless it's soda?
  7. #525
    May 2012
    lancashire
    1,251
    2214
    yeah it does really, i need the inner sills bare steel before the body is welded on also i would have everything bar the main panels done as sand blasting would warp them. im planing to have the whole car dipped to strip it down to bare metal and then dipped in primer so that even inside the chassis its protected as i want it to last.
  8. #526
    Official RnS Addict ludsonline's Avatar
    Jan 2011
    Suffolk
    527
    422
    4
    ludsonline is offline
    Maybe try these guys m8? Envirostripukltd There is also Surface processing but my m8 had his 21 window VW damaged by them with a fork lift
  9. #527
    Cheltenham
    4,078
    601
    fozwanger is offline
    That nearly sits back as far as mine!!!! Looking good
    Quote Originally Posted by chop top mk2 View Post
    big update today, been working on the front chassis rails. got them tacked in with just the front rails to kick down to tie into the original frame in the nose of the car.
    with the front being so narrow every thing seems to fit ok. you can also see how much the engine is set back in the frame.
    even with the wheels at more than full lock theres loads of room. pleased with what i got done today and i still have a day left to attack it so more pics tomorrow.
  10. #528
    Cheltenham
    4,078
    601
    Just read the thread from the start and very impressed. The only thing that's a weak link is the gearbox. I've broken a few running P6 motors and totally mashed one when running twin turbo's on a stock SD1 motor. I've opted for a T5 for my motor. Also, when I ran the TT set up before I had no mufflers, it didnn't need them until the waste gates opened but I didn't care on full throttle in third!!!!!
    Are you going for a blow thru set up? I'm going down the injection route as the overall outlay isn't much different.
    What spec are you building the engine too?
    Very nice
    Jeff
    p.s. You make my welding look utterly ****
  11. #529
    May 2012
    lancashire
    1,251
    2214
    cheers jeff,
    for this engine will be running the blow thru set up just to get the car on the road will then build another engine to handle the 36 pounds of boost the turbo will make i would love to put one of those easy set up efi carbs on. so i guess it will be steel crank, h beam rods and forged pistons and all the other goodies it will need. planing to stay 3.5 as well.
    i did have a t5 box , the problem with them is third gear (mine had a duff third gear), talking to a few people they all say that cossies break that gear and they are expensive to repair so i sold it.i chose the lt box as it.s really short and would suit my application. the engine is a long way back, the whole chassis was designed around it.
    bit of a surprise yesterday got the wheels and rear hubs back from the m/c shop so got it all bolted back on this mourning and it all fits ok and also the car now rolls, result.
    this coming week i now have the bits to sort the handbrake so will get on with that. more soon
  12. #530
    Official RnS Addict ifan.miller's Avatar
    Apr 2010
    BRIDGEND, SOUTH WALES
    4,607
    1461
    ifan.miller is offline
    this thing looks plain nasty keep up the good work
    1. Mk2 Zodiac Dash Top
      Last Post: 25-03-2010, 20:59
    2. chop saw/ w/shop heater
      Last Post: 31-07-2009, 04:57
    3. mk2 consul bits
      Last Post: 08-05-2009, 20:30
    4. zodiac mk2
      Last Post: 30-04-2009, 19:43
    5. Transit MK2 steering box
      Last Post: 28-04-2009, 20:54
