Consul Capri Rebuild
Likes Likes:  3
Results 1 to 10 of 38
    Oct 2010
    Hinckley
    181
    59
    Motorvating is offline
    My consul Capri went in for a respray and turned into a restoration
    Before
    Then we came across copious filler
    We found filler so thick in parts that is was 1/2 " thick.
    New panels required from old.repaired stock for both front wings, repair panels for door skins and rear 1/4 panels, new flutes for side lights and repair panels for valance where it meets the side light flutes.
    Official RnS Addict 1stpop's Avatar
    isle of sheppey kent
    2,484
    48
    1stpop is offline
    So what's your plans then mate
    Feb 2010
    flimwell,east sussex
    1,814
    4
    bedford ca freak is offline
    Still waiting to start on mine so keep on posting the progress as i have a feeling mine has a serious amount of plop in it.
    23,569
    Quote Originally Posted by Motorvating View Post
    Then we came across copious filler...
    ...We found filler so thick in parts that is was 1/2 " thick.
    Mick worked in a bodyshop , standard practice, all mine probably have that much in them! You don't start out with a plan to put that much filler in, often you have no idea of how much is in there .As long as it's over steel and not chicken wire and old newspapers I don't see a problem ? There's a reason old custom were called leadsleds , just it was lead that thick not filler . If you can't see it until you start cutting it out then it's a good job done , especially with many years usage on them.
    Depends how much you are willing to spend while building. One guy bought one of mine and moaned that it had filler in it , he thought he was getting a brand new panel and all lead loaded car ,didn't even buy it from me. He bought it for almost what the chroming bill came to.
    When Mick built that he had 2 kids and a big mortgage but a NEED to build something, which he did on a budget, just like I did mine.
    A guy locally bought a well known Capri from the late 80s for £1500 last year, looked almost as clean as yours in the before shots ,he's done over £10k on it SO FAR !
    Oct 2010
    Hinckley
    181
    59
    I agree and filler will be used again once the fettling has been done. It is the welding thats caused the problem. What I'm saying now is from the body shop not me. The amount of filler used was because of the poor standard of plates welded in i.e. metal work wasn't beaten out to shape and then a skim of filler, but rather the repair patches were to rough shape then liberal amounts of filler used. On several parts of the car the dayton line (think the words correct) was lost due to the above mentioned causing so much filler to be used in places. What the body shop said, and was a point of confusion to them, was the bits of bodywork you can't see e.g. inner wings etc was to a very professional standard, but the bits you could see was a totally different standard.
    Oct 2010
    Hinckley
    181
    59
    Quote Originally Posted by 1stpop View Post
    the body paint will be a purple shimmer, and roof purple with a white pearl sprayed over, so it looks white but a hint of purple comes through as light hits it. Leaving the V6 Essex and later Capri running gear as it is. Will be lowered, lake pipes and hopefully skirts if my budget stretches that far. Interior will remain white and is in the upholsterers being refreshed with repair panels and cleaned.
    If you have a look on the clubs FB page, you will see an advert from an old coachbuilder/panel beater who makes most panels by hand at a reasonable cost, and what is not currently made can be repaired. He is very very good.
    Oct 2010
    Hinckley
    181
    59
    Finally got all the panels to start work.
    Having real problems with the refurbished wing as there is a 20mm gap between the headlight panel and wing grrrr
    Oct 2010
    Hinckley
    181
    59
    More pictures
    23,569
    I always do the wings on the car for that very reason .If they've used club repairs panels they aren't a good fit anyway . Plus even from the factory there is around a 10mm gap that is filled with mastic strip as standard. Like the doors almost bang on the back edge of the wings but you can get your finger in the gap at the back. Not enough play to set them up correctly without slotting the holes in the A pillar , where the hinges mount , that allow adjustment.
    Oct 2010
    Hinckley
    181
    59
    cheers kev, useful info
    1. Ford Consul Capri
      By Rump Shaker in forum Vehicles - FOR SALE
      Last Post: 27-05-2010, 21:27
    2. Consul Capri
      By Acker in forum Vehicles - WANTED
      Last Post: 18-05-2010, 15:51
    3. Consul Capri
      By Bronxglenn in forum Stuff - WANTED
      Last Post: 15-05-2010, 18:28
    4. classic consul capri bumpers
      By spider in forum Stuff - FOR SALE
      Last Post: 11-05-2010, 21:09
    5. consul capri parts
      Last Post: 11-09-2009, 08:49
