Ford F-350 jaguar straight six xjr powered....... Hopefully - Page 3
Likes Likes:  9
Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 58
  1. #21
    Official RnS Addict vin likes diesel's Avatar
    London
    2,801
    1527
    vin likes diesel is offline
    Had a couple of hours and a box of new old stock hoses, brand new jaguar v6 rad and a couple of joiners made.
    Pro Street Escort... MOT ready.
    Hug Street Morris Oxford mo.... unfinished, on its tenth set of wheels
    Custom truck ..MOT ready
    Dinner ....finished
  3. #22
    London
    2,801
    1527
    Had a clearance issue with the tpi oil switch once the loom was plugged on so had to alter the exhaust header so now I have clearance
    Dinner ....finished
  4. #23
    London
    2,801
    1527
    Rad mounted
    Dinner ....finished
  6. #24
    London
    2,801
    1527
    So the list gets shorter.
    Gearbox xmember made.
    prop made.
    exhausts made
    couple of engine aux brackets.
    Have put the prop ubolts some where safe but im sure they will turn up. need to buy some bolts and jubilee clips.
    Some more wires to fit, a couple of relays, engine oil and filter, antifreeze, the little union that goes on the end of the shifter cable to gearbox selector lever, throw some petrol and a battery and see what happens……..
    Dinner ....finished
  7. Likes296moon liked this post
  8. #25
    London
    2,801
    1527
    Got the new headlights fitted.
    Dinner ....finished
  9. #26
    Jun 2009
    romford essex
    3,008
    1170
    296moon is offline
    Keep at it Vin, youll soon be able to change your Tag list
  10. #27
    London
    2,801
    1527
    So today I turned the key and it no fuel pump noise, hot wired the pump and then I turned the key and it fired up run for 3 seconds then died, fired and died, fired and died, certainly a step in the right direction.
    Dinner ....finished
  11. Likeshurtz liked this post
  12. #28
    London
    2,801
    1527
    So far the 9th injector is the only thing making the TPI fire, fuel pressure is 45psi ignition on, had a funny noise from the air intake which was the idle valve, as I took it out the plunger shot off across the workshop.
    Got 4 more injectors to check the ohms as four read 16.8 ohms, I have drilled the manifold air temperature sensor bung from the bottom of the air intake and welded it to the top near the distributor. I took the cap off to look inside and the module wires were corroded together so have ordered a new dizzy ,IAC valve, and a TPI service manual from Australia so hopefully I can get it to run
    Just going to check the ohms and power supplies.
    Dinner ....finished
  13. #29
    London
    2,801
    1527
    Dinner ....finished
  14. #30
    London
    2,801
    1527
    All injectors checked out on the ohms.
    Manifold air temperature switch and the coolant temperature switch both worked on the ohms , the colder they got the more ohms they produced.
    Got to change the starter solenoid as my one is broken.
    Dinner ....finished
There are currently 2 users browsing this thread. (0 members and 2 guests)
    1. Replies: 0
      Last Post: 04-07-2015, 18:28
    2. Jaguar straight six xk engine wanted
      By Scaf in forum Stuff - WANTED
      Last Post: 25-04-2014, 19:31
    3. ford straight six
      By v8beetle in forum Stuff - WANTED
      Last Post: 10-07-2011, 20:48
    4. Vauxhall or Ford straight six?
      By timetravel in forum On Topic
      Last Post: 25-05-2011, 06:56
    5. Replies: 2
      Last Post: 25-11-2010, 22:09
