Medusa - Page 315
Likes Likes:  453
Page 315 of 324 FirstFirst ... 215 265 305 313 314 315 316 317 ... LastLast
Results 3,141 to 3,150 of 3237
Thread: Medusa
  1. #3141
    Jan 2010
    Swindon
    954
    125
    MYTHING is offline
    OK So ram air induction by Robert rather than Suzuki, It doesn't matter how you crack the egg so long as it cracks so your approach should overcome the issue, waiting with baited breath now.....
  3. #3142
    Aug 2015
    haarlem the netherlands
    316
    watahyahknow is offline
    i can allready see him working a bathroom plunger over the trottlebodies
    https://www.youtube.com/watch?v=9mtdEH43r2s
  4. Likes28Chevy liked this post
  5. #3143
    Feb 2013
    uranus
    2,073
    ivanhoew is offline
    Quote Originally Posted by MYTHING View Post
    exactly, i am looking forward to the first crank , bearing in mind both engines will have some dodgy old secondhand multi spark uber poweful sparks boxes , and the lpg will not be calibrated in any way for the engines , there could well be a set of 12 bellmouths hurtling off over the neighbouring hedge ,and the titanium pipes may end up dead straight !
    Bicester scramble ,Medusa enjoyed the trip.https://www.youtube.com/watch?v=Q-7I7-nA19U
  6. Remove Advertisements
  7. #3144
    See, I told you I was sic ColinHD's Avatar
    Jan 2010
    Back in the UK Weston-Super-Mud
    593
    355
    ColinHD is offline
    I'm struggling to get a 4 pot Beetle to run!
    Fantastic job to even attempt joining two engine together, way above my backyard skills
    " Big Mess - I'll get back to you"
    Ed Roth - "I couldn't get enough of his stuff, cos he understood!" - 28Chevy
  8. #3145
    Feb 2013
    uranus
    2,073
    ivanhoew is offline
    Quote Originally Posted by ColinHD View Post
    pppfft don't even start with skills colin you sculptore amazingoire !!
  9. #3146
    Dec 2010
    Near Canning Town, London
    1,630
    1728
    Taxirod is offline
    Hi Robert
    I haven't looked in for a while......Wow you aren't afraid of stuff which i can barely understand, let alone attempt.
    And i thought I had problems!
    I'm sure you'll get it all sorted, look what you've accomplished already!
  10. #3147
    Feb 2013
    uranus
    2,073
    ivanhoew is offline
    Quote Originally Posted by Taxirod View Post
    Hi Robert
    thank you ian , much appreciated
    i did a little bit of work today , i plugged the ecu into a simulator on the dining room table , all worked as it should , i could twiddle knobs and watch the revs change etc on the laptop ,so all my soldering has not killed anything .
    Next i connected a pc based oscilloscope leant to me , and checked to see if my two separate ignition signals ,one for each engine ,were working ,and also see if they were 45 degrees apart as set in the software ....
    the purple is one signal ,the orange the other , and along the bottom of the graph is time , and up the side is voltage .
    you can see the switching where the zero volts switches to 5v , then back to zero ,.which triggers the msd ignition box to fire. also you can see the purple and orange signals are changing voltages at different times , as is needed for my bizzarre engine setup ,where the back engine fires 45 degrees after the front , its all looking a bit promising .
    regards
    robert
  11. #3148
    Oct 2015
    Sussex by the sea
    822
    95
    28Chevy is offline
    When the late Micheal Oliver (Great Dorset Steam Show founder) was asked what kept him going, he said with his big chuckle “I think it’s quite nice to be a bit big headed and know what a good job you’re supposed to have made of it, and I thoroughly enjoy that”
    Be like Micheal to avoid a fading mojo..
  12. #3149
    I'm a newbie !
    Aug 2015
    Hebden bridge
    7
    Slim_adi is offline
    Are you Neo ? Does your missis plug you in and tap the keyboard ? Do your eyes flicker and then you say “i know car stuff” ?
    How the heck do you know all this stuff ??
    I can barely locate the dipstick on my heap !
  13. #3150
    Feb 2013
    uranus
    2,073
    ivanhoew is offline
    Quote Originally Posted by Slim_adi View Post
    hahaha thank you Slim , bizzarely one set of injectors are called matrix injectors ...i really do need to get some decent sunglasses for summer
    1. Medusa guitar
      By evilzee28 in forum Chat
      Last Post: 19-03-2013, 12:58
