Medusa - Page 319
Likes Likes:  570
Page 319 of 353 FirstFirst ... 219 269 309 317 318 319 320 321 329 ... LastLast
Results 3,181 to 3,190 of 3529
Thread: Medusa
  1. #3181
    Feb 2013
    uranus
    2,352
    ivanhoew is offline
    HA , i think its 5 steps sideways ,then a little mince forwards , then a rest lol.
  3. #3182
    Feb 2013
    uranus
    2,352
    ivanhoew is offline
    Hello my little vol au vents , i trust your filling is tasty and your pastry crispy and golden ?
    it is ??
    they are ???
    oh GOOD . i can relax.
    This week i have mostly been eating spinach and feta ,with a maybe a heartening beef broth on the odd occasion .
    i started in on the car again on Tuesday , Sunday and Monday being devoted to a very rare thing , PAID work !
    After the shock of that i set to trying to get the blessed thing to make some sense .
    I could not get it to flash my normal timing light , to set the ignition timing ,on cranking , so i dragged my huge heavy sun tester out of the corner of the batcave to see if its strobe would work ,,,the answer was a little bit , so i did my best to adjust the ecu to give me a flash when i wanted it .
    then did a continuity check on the feed to the front injectors , , all seemed good ...what could be wrong ? i put a direct supply to the injectors and they clicked so that was a relief , ,so i then examined the 7.5 AMP fuse in the line for E! yup ,blown ,popped in a svelte 10 AMPER ,, i also checked the injectors would open against gas pressure and they did .
    So today , i carried on , i put the ecu on a simulator and checked it was sparking properly ,for the 45 degree split between engines , and the injection pulses looked ok too , so popped it back on the car .
    now my battery or starter ,or both,are now a bit sick of all the cranking ,bit like a manual light house keeper , and ,like a teenager going to thier first night club , i was not too hopeful of action, but hey , jumpered another semi sick battery on there , and my starter charger and went for it ...
    NUFFIN.
    i started adding fuel , more and more , went from a 2.1 ms pulse width to ,in the end .a 8ms pulse .
    cranking got slower and slower , mirroring my energy /optimism quotient nicely !
    then finally it all came to a head , and i am afraid i have more bad news ...
    FOR OTHER ROAD USERS !!!!!!!!!!
    IT ONLY BLOODY STARTED !!!!!....!!!
    yup , the poxy thing was teasing me all along,and it fired right up , revved nicely round to 3000 rpm with no problems , all pipes hot and cylinders FIRING ...OI VEY ,,, i could not believe what i was seeing .
    so there you go ...tomorrow i can actually start to tune it a bit and get mapping , hugeness
    regards
    robert
  4. #3183
    Jul 2010
    garden of England
    578
    27
    thisYup is offline
    hurrah, and channelling some classic Kenny Everett's Marcel
  6. #3184
    I'm a newbie ! Piguin's Avatar
    Jun 2018
    San Diego, California
    14
    Piguin is offline
    Its Aliiiiiive!
  7. #3185
    Aug 2010
    Melbourne Australia
    94
    Gojeep is offline
    Awesome news.
  8. #3186
    I'm a newbie !
    Mar 2019
    11
    Peanut Gallery is offline
    Brilliant! - that first pop pop is a brilliant sound after working on a car for so long!
    (Now go stick the battery on a charger please!)
  9. #3187
    I'm a newbie !
    Sep 2018
    4
    Gazzam is offline
    Give it the berries!
  10. #3188
    I'm a newbie !
    Dec 2016
    Stoke on Trent
    Olliesgrandad is offline
    it is ??
    they are ???
    NUFFIN.
    regards
    robert
    Great news Robert. Much excitement here.
    Mark.
  11. #3189
    Jan 2010
    Swindon
    994
    129
    MYTHING is offline
    Great news and I bet nobody is more pleased relieved and happy than you
    WOW What a great result
  12. #3190
    Feb 2013
    uranus
    2,352
    ivanhoew is offline
    Thank you chaps ,
    So a touch of progress ,put the old girl on the dyno to try to sort the lower down fueling ,spent a fair while using the normal speed density system , so that MAP up the side of the graph , and rpm on the base .
    trouble is , i was not getting much vacuum signal , despite pulling vac from 6 cylinders into a small collector .
    so i went to the megasquirt ITB mode ,and this seems a fair bit better , i set it up according the video on this on yuotube , as much as i could anyway with not a lot of logging data .and after a bit of remapping it revs like a goodun .
    Went for a mile on the rd to see if i thought it would make it to the local car show 6 miles way , and it felt good , so set off in the evening after supper to drive the 6 miles ,fill up the tank ,and pop into the show .
    this all went well ...
    and of course on the exit it had to accidentally break traction in 1st and 2nd , and ,later on , accidentally punching the throttle broke the tyres free at 60 in 3rd ...its definitely a lot more pokey ,,and very smooth ,not perfect , there are lean bits and rich bits ,but happy i made the change and hopefully less fuel used .
    one anomaly i found this morning is ,
    here is my timing map ..
    and here is the timing i logged ..
    so that is very bad on a 11.6:1 compression ratio .
    research continues ,,maybe a ITB mode glitch , but more likely me doing something stupid with the setup ...
    regards
    robert
There are currently 9 users browsing this thread. (0 members and 9 guests)
    1. Medusa guitar
      By evilzee28 in forum Chat
      Last Post: 19-03-2013, 12:58
