Medusa - Page 330
Likes Likes:  490
Page 330 of 332 FirstFirst ... 230 280 320 328 329 330 331 332 LastLast
Results 3,291 to 3,300 of 3312
Thread: Medusa
  1. #3291
    Jan 2010
    Swindon
    977
    125
    MYTHING is offline
    Hi Robert
    Saw you at Bicester but as you were heavy in with your loving followers I could do no more than nod.....
    Car looks fantastic, didn't see V she was probably sensibly getting hot drinks, great show, very eclectic but cold.. ah well this is England
    Regards
  3. #3292
    Feb 2013
    uranus
    2,164
    ivanhoew is online now
    Quote Originally Posted by MYTHING View Post
    Hi Robert
    Regards
    Hi Paul , oh that's a shame i would have preferred you came and nudged me ! it was a bit of a chatfest.... i had several people at once asking me questions, i felt like an umpire , all very friendly though.i must put a data sheet on the car.
    at least you can look at the car , and say to yourself , hey,loads of that was made in my huge mega vice of wonderfullness !
    RR
  4. LikesMYTHING liked this post
  5. #3293
    Feb 2013
    uranus
    2,164
    ola compadres ..
    Well not a lot happened this week , APART FROM I GOT MY V5C !!! with the new number on ....
    Now...going insane trying to find the font i want in a plate that doesn't cost 9 million gatrillion pounds ..cannot even find stick on letters ! blimmen charles wright !!
    meanwhile i have a scrappy cav mk1 ign module for the front engine so i can have matching coils ,as the twins in the gynacologist requested , also still researching my inj malfunction.
    no driving going on since its be noah'sville here , i did spend a happy few hours angle grinding the rust off my guards , , during which i found a crack in th top mounting bar on the hub , so whipped that off and braced it with a 6mm s/s bar of goodness ...that won't crack again !
    i wondered why i could smell rubber on the way home .
    tinkety tonk.
    regards
    robert
  6. Likessteve1275, Andy650 liked this post
  7. Remove Advertisements
  8. #3294
    Feb 2013
    uranus
    2,164
    guten aben ,
    My Mission for this week ,which i chose to accept , was to fit my SLC free wide band exhaust gas fuel mixture dubries .
    They look like this ..
    which just won't do , it's about as gentlemans roadster as a shell suit and a burberry scarf dontchaknow ... might as well get huge fake bum implants while i am at it !! #innap.
    so my evil plan is to take the 0 to 5v read out , run it through my friends box of tricks , which will give me a 1 to 2v output ,then ,if the air fuel ratio is 10:1 to 20:1 , then a voltmeter will read the air fuel ration directly ,just with the decimal point in the wrong place ..triffic.
    i soldered the SLC's as shown in the instructions ..
    thats all those little soldered points in the front , and the 4 and 6 pin end plugs , then i painted the case satin black , since i will have to have them visible to see the o2 senor temperatures , i will pop them in the side of the scuttle .
    next was to mount the mounts for the digital readouts , which you have seen a page or two back , these i simply drilled through the scuttle and used s/s button allens... m5 i think todays particular vintage was .
    NOW , since i had burnt out my digital temperature sensors with a jump start , i did a bit of research , and found they are not at all happy over 15v .so i wandered through ebay , and found a little stamp sized adjustable voltage regulator , bought it , and hooked it up to try it out ...
    first i connected it to 12v bench supply , and popped a 12v led on it .
    then adjusted the weeny little pot on the regulator to give 9volts ish ..
    marrrvelous , hopefully that may protect the 4 digital readouts about to be unleashed on the car .
    so i popped in my new temperature dig RR's and lo and bloody behold , one of them read 95c ! pox.
    spent another happy half hour working out the sensor had gone spasmo ,so cut, soldered, and heat shrunk the bejaysus out of it and we were beck to functionnositynesstasticnoodle.
    Went ahead and constructed my customary cats cradle of wires behind the demi dash ...
    having already mated the voltmeters with their respective hosts .
    next was to turn it all on ..
    HG WELLS !! pfffft ..take a back seat buddy
    ok ok maybbe not , but hey , i like em .
    next is to fit the boxes , wire it all up , and then i get constant real time air fuel ratio feedback ,with no big innovate boxes clumping up the seat , neaty neat neat .
    regards
    robert
  9. Likes28Chevy, steve1275 liked this post
  10. #3295
    Rods 'n' Sods Junkie Andy650's Avatar
    Oct 2013
    Eastleigh
    114
    16
    Andy650 is offline
    That look terrific. I wouldn't believe that digital readouts would look good alongside a traditional brass dash but by eck they do
  11. #3296
    Feb 2013
    uranus
    2,164
    Quote Originally Posted by Andy650 View Post
    thanks Andy , i was of the same mind , but thought hey ,you only find out by actually doing it and seeing how it looks .
  12. #3297
    8,887
    1759
    blackpopracing is online now
    It's all voodoo!!
    Robert is an alchemist!
  13. #3298
    Feb 2013
    uranus
    2,164
    it's true !..
    Me....with a beard ^^^^^^
  14. Likes28Chevy liked this post
  15. #3299
    Oct 2013
    Eastleigh
    114
    16
    Andy650 is offline
    Looks like one too many lightening holes drilled in that flywheel bottom left
  16. Likes4potHemi liked this post
  17. #3300
    Nov 2010
    Bedford
    1,842
    1149
    Flying Phil is offline
    Spooky well done Robert!
  1. Medusa guitar
    By evilzee28 in forum Chat
    Last Post: 19-03-2013, 13:58
