Medusa - Page 347
Likes Likes:  546
Page 347 of 348 FirstFirst ... 247 297 337 345 346 347 348 LastLast
Results 3,461 to 3,470 of 3471
Thread: Medusa
  1. #3461
    Nov 2010
    Bedford
    1,894
    1149
    Flying Phil is online now
    Looking good with the 4 piece Robert.....
  3. #3462
    Milton Keynes
    1,075
    21
    Magman is offline
    I’m definitely pro it being completely polycarbonate. My first thought when I saw it with the black band at the bottom of the sections was that it looked like a tally ho moustache!!
    ‘Tache twizzling required!
  4. #3463
    Feb 2013
    uranus
    2,295
    ivanhoew is offline
    Thanks chaps , got the other side roughly done today ,
    next is to make and weld on the mounting tabs for the lower bits , and then take it all apart and spend 190000000 hours trying to 1200 ,2000 , polishing mop all the gouges and scratches out of the PC .
    THEEEENN ....make the centre post mount .
    oh such fun
    regards
    robert
  5. Likesalan liked this post
  6. Remove Advertisements
  7. #3464
    Aug 2010
    Melbourne Australia
    93
    Gojeep is offline
    Any reason why you cannot just make it one piece each side? Have you run out of material?
    Also maybe some rubber channel if not alloy on the bottom edge?
  8. #3465
    Feb 2013
    uranus
    2,295
    ivanhoew is offline
    yes marcus , scrappy only had a small amount of 8mm PC . i am investigating the bottom edge , i did make a bit of copper ..
    out of 10mmm pipe , but i think its a bit too much , i can try different edgings once its all assembled , to get a more accurate idea of what to use .
    regards
    robert
  9. #3466
    9,157
    1773
    blackpopracing is offline
    That looks really good - virtually invisible.
    For me - I would just make a little ally lip 'L' shaped to rivet to the body and bridge the gap to cover about 10mm of the bottom of the screen. This should be enough to stop water getting underneath.
  10. Likesmygasser liked this post
  11. #3467
    Feb 2013
    uranus
    2,295
    ivanhoew is offline
    little more done today ...
    I was going to make a strut to support the centre post ,however , i decided i liked it floating and looking unsupported , so i made a little plate to
    cantilever off the bonnet hold down bolt ,which clamps down onto a 12mm x 100mm thick ally beam under the bonnet ..., so is nice and rigid ...
    i made the plate out of a particularly tough stainless which was a brstd to drill, if it proves to be too thin i can use it as a pattern to make a thicker one .
    tomorrow i get on with the welding of the tabs to the posts ...and polishing the poly.
    regards
    robert
  12. Likesmygasser, 28Chevy, steve1275 liked this post
  13. #3468
    Feb 2013
    uranus
    2,295
    ivanhoew is offline
    Well this is a fine parcel of sour meringues and no mistake .
    got the next 4 tabs made and welded on ,then onto the strut ends...
    i found that the thread in the end of the struts is a super fine left hand thread , so tapped the middle strut to m16 x 1mm ( no idea why i had that tap ?)
    anyrdup , on to the outer struts , one of then had a fitting in it , cut flush ,,so that had to come out , i used a 10 mm carbide burr in the die grinder ,and ground a slot in it , just down to the threads, then put a groove into the other side till it got a bit wobbly , then unscrewed it ..
    ,all going well you may say , the clarion call , "he's getting on with it" , may well echo across the defensive towers and dykes of olde englande ..! ...er...
    no.
    cos now we come to the insectipoid in my germolene.
    tying to get the scratches out of my bits .
    here's a bit ...
    you can see the down side to getting it from the yard where it has been ripped off a bit of machinery with no thought for me AT ALL !
    yup, its well and truly scratched up ,looks like my ankles after i was chased by that girl in pernumbuko with the 3 inch nails that i only escaped by climbing up a rare deciduous equatorial fir tree .
    i tried all grits , from 80 to 2000 , i tried cloth wheel and paste , you name it i tried a combination of it , the 80 grit marks would not come out , the 120 grit would not take out the scratches , i tired the da and compressor , A LOT, best i could get was this ..
    still pretty hazy , so i am a bit stoooofed , no idea what to try now , i suppose options are ..
    try and find a place to polish it for me .
    see if i can find new for less than polishing costs .
    make the top bits out of glass and try to drill holes in it ..
    find a better way to polish it myself .
    oh woe woe woe is me
    regards
    robert
  14. #3469
    Milton Keynes
    1,075
    21
    Magman is offline
    There’s mobile guys out there that come out to you to polish the plastic headlight lens on modern cars. The headlights on my son’s Audi TT were scratched to hell and really foggy like a night in ye olde Londinium.
    Chappy turns up with his little van of tools and witchcraft, an hour later and they were so clear you couldn’t see the lens at all...cost him 45 folding beer vouchers......it could be worth a try?
  15. #3470
    13,265
    mygasser is online now
    i always use some g3 compound on plastic headlight lenses, some need a bit of wet n dry first but always eventually come good. you may just need the patience of job to get it done mate (''have the patience of Job. To have an immense and unyielding degree of patience and conviction, especially in the face of problems or difficulty. A reference to the biblical figure Job, whose absolute faith in God remained unshaken despite the numerous afflictions set upon himself, his family, and his estate by Satan''). i've no doubt you have the conviction and will persevere to the bitter (and shiny) end.
  16. LikesTaxirod liked this post
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. Taxirod
  1. Medusa guitar
    By evilzee28 in forum Chat
    Last Post: 19-03-2013, 12:58
