Medusa - Page 351
Likes Likes:  560
Page 351 of 352 FirstFirst ... 251 301 341 349 350 351 352 LastLast
Results 3,501 to 3,510 of 3511
Thread: Medusa
  1. #3501
    Feb 2013
    uranus
    2,324
    ivanhoew is online now
    Well today dawned sparklingly blue and pristine , so i hoicked on my Gay M.T.B. Captain hat and shades , jumped in the old battlewagon , and shoved off for the shops .
    Put a tenner in at the petrol station , waited for photographers to finish , then off to lidl's for my first shop in 4 moths .spoinged out of the car like zebedee (magic roundabout) and donned my mask of secrecy ,shop was pretty empty , so whizzed around ,and all was well .
    Loaded it all in , fired up ,and drove out , waited at the lights then the roundabout ,and off i went down the straight to home ...er...well....not so simple......
    Casually glancing at the dashboard i purloined off the Nautilus, i suffered a slight miasma of shock , my vision clouded, and i had to rub my eyes in that , american hero about to attack a jap aircraft carrier in a sopwith camel.... sort of way..
    Yup , my temp gauge for the 4.0 litre engine no .2......(normal reading 85c)..... was reading 112 degrees c !
    ...my internal "god awlmighty" was interrupted when i then noticed the rad water pressure measuring device , was communicating the shocking out of this world fact , that the internal cooling pressure , instead of being the normal 5 to 7 psi , was ..wait .for .it.....wait for it....
    TWENTY BLOODY FIVE PSI OF HEAD GASKET BLOWING GOODNESS !
    At this point i realised i had not tuned the water pump on .
    After booking myself in for a thorough barbed wire flagellation session upon my return , i carried on fluffing the throttle to keep the engines as far below actual aluminium meltdown as possible , 1200 rpm at 45 mph , and watched the dash board for signs of hope .
    the rd pressure came down to 12 to 15 ....15psi is the cap blow off level ...
    front engine was at 95 , rear stayed at 110c .all...the...way...home.....
    drove in , hoofed the bonnet off , and got the garden hose on a "light fairy bath gossamer misting" setting (that's setting no2 in the instructions) , and wafted it over the blocks , upon which point the water droplets cracked off like fire crackers , bit like spitting in a hot frying pan ...it was hot.
    kept this up for 10 mins ,pressure dropped ,so also took off the rad cap , and trickled , very slowly , water in with the pump and fans on .
    bit the bullet , and fired her up (but in the normal way ) , and she sounded ok , no bubbling into the header tank , so maybe , just maybe i got away with it .
    i think , basically , i was driving with no water in the car , and a 11.6:1 compression ration , for about 5 miles .....
    looking on the bright side , all the oil leak stains on the engines have disapeared ..it was so hot it burnt the oil right off and degreased themselves ..
    anyway , one fun fact i noticed on the log for the drive ...
    that timed section is me wheelspinning down standlake main rd in second gear , it goes from 2217 rpm , to 5220 rpm in 0.884 seconds ,,,,that's what you get with 7.6 litres of goodness , and only a 35 lb flywheel .
    I'll allow it
    regards
    robert
  2. Likesmygasser, steve1275 liked this post
  3. Remove Advertisements
  4. #3502
    Jul 2010
    garden of England
    575
    27
    thisYup is offline
  5. #3503
    Feb 2013
    uranus
    2,324
    Quote Originally Posted by thisYup View Post
    I know !
  6. Remove Advertisements
  7. #3504
    13,384
    mygasser is online now
    hoodathunkit
  8. #3505
    Sep 2019
    Nr Malvern, Worcs
    212
    budetta is offline
    I fitted a thermostatic switch on my race car just in case I forgot to turn fan and pump on, works!!
  9. #3506
    Feb 2013
    uranus
    2,324
    Quote Originally Posted by budetta View Post
    yes i think i must rig up something , i have the pump off to help the battery crank it over , , maybe a relay in the pump feed , that switches off during cranking .
  10. #3507
    13,384
    that'd work, of a timed relay that powers the pump a preset time after the ignition is switched on.
  11. #3508
    Jan 2010
    Swindon
    994
    129
    MYTHING is offline
    Or a big GOON light that's on when the pump is off and off when its on
    A standard relay to operate the light using the switched power on to switch the relay off
    Or one of your inventive solutions
  12. #3509
    Milton Keynes
    1,109
    24
    Magman is offline
    A steam whistle for when it gets too hot? I reckon that’d fit in nicely with the style of Medusa
  13. Likesmygasser, kapri liked this post
  14. #3510
    Feb 2013
    uranus
    2,324
    Quote Originally Posted by Magman View Post
    now that's another good idea .magman .,,,you're on fire !
There are currently 33 users browsing this thread. (0 members and 33 guests)
    1. Medusa guitar
      By evilzee28 in forum Chat
      Last Post: 19-03-2013, 12:58
