mk1 zephyr tear down and respray starts
Likes Likes:  2
Page 1 of 14 1 2 3 11 ... LastLast
Results 1 to 10 of 133
    Rods 'n' Sods Junkie pkingesq's Avatar
    Nov 2011
    Mansfield
    205
    575
    144
    pkingesq is offline
    Was a simple idea, quick respray to change the colours, freshen up the engine and check all the electrics, so the plan was only go back to metal in places ..... however various people suggested it would be best to go right back to bare metal so here goes, this is not going to be a quick job but I have promised my self an hour a day minimum whether I want to or not so today as I was not at work I started.
    Any tips for getting the filler out of the seam at the top of the wing gratefully recvd.
    Nov 2011
    Mansfield
    205
    575
    144
    pkingesq is offline
    Zinc primering as I go to avoid rust hopefully as metal roof on garage drips
    6,357
    1065
    English Impala is online now
    Warm the area with a hot-air paint stripping gun to soften the filler and scrape at the filler with a thin blade (a screw driver ground down is good). Don't be tempted to use any sort of stripper/chemical, once its in the seam its difficult to get it out!
    Nov 2011
    Mansfield
    205
    575
    144
    pkingesq is offline
    cheers will try that tomorrow
    Leicester
    5,697
    594
    bigyellataxi is offline
    Did you ever find out what the oil leak was at the HRD's???
    P.s. good luck...
    Hidden Content
    Fueled by Jim and Luckies.
    Lee
    Fat 'n' Loud Lee's Avatar
    Derby
    4,766
    493
    Lee is offline
    Quote Originally Posted by pkingesq View Post
    Wire brush in a drill.
    Rods 'n' Sods Junkie neil.w's Avatar
    Oct 2012
    middlesbrough cleveland england
    259
    neil.w is offline
    You beat me to it Lee:incheek :or a cup wire wheel in a grinder Cheers Neil
    Nov 2011
    Mansfield
    205
    575
    144
    pkingesq is offline
    Tried the wire brush both cup and wheel but the depth of the seam and the welds joining the 2 halves of the wing wire brushing just don't get in far enough to get it all out. Yellataxi, was water not oil and seems I have a dodgy core plug that only leaks when under pressure, this is what started the tear down - figured as engine coming out might as well respray
    Rekindled Dream Chunky's Avatar
    Aug 2009
    Moston, Manchester, UK
    2,064
    70
    Chunky is offline
    I'd do what you can with a bevel wire brush in a grinder and what is left in the seam is left so long as there is no rust evident (or was there?) I think you'll be fine. Can I ask was there anything wrong with the paint? As in the pics it looks fine? Is it to just change the colour? If so I'd stop where you are, as you seem to be unveiling repairs that appear to have been successful as the finish looked good.
    If the idea was just to change the colour then just do that. Sand back to primer and then respray. You now have to filler a etc on the bits that you've stripped so far.
    Ok about respraying the engine bay while the engine is out but that involves lots of work stripping out everything to do it properly. Is it that bad or would deep clean and buff up suffice? Unless a totally different colour is envisaged.
    The benefit of stripping the paint totally is you know what's underneath so in future you know where the likely trouble spots might be.
    Hope this helps ... Jon
    Life's journey is not to arrive at the grave safely in a well preserved body , but rather to skid in sideways, totally worn out, shouting "Holy shit ... what a ride"
    Official RnS Addict 55zephyr's Avatar
    Mar 2010
    Brentwood
    533
    138
    14
    55zephyr is offline
    I totally agree with all that Jon has said. I do believe you are making yourself a lot of hard work for a change of colour. Your garage, being damp isn't the ideal place to take the car back to bare metal. All of the panels unbolt from the main shell for ease of prepping and painting, every bolt being stainless steel. I would have removed these and taken the drivetrain out before embarking on the facelift job, but that's only my opinion. Good luck, Ron.
    Older but no wiser.
  1. Replies: 3
    Last Post: 26-02-2011, 21:18
  2. mk1 zephyr glass front wing
    By slickback56 in forum Stuff - WANTED
    Last Post: 20-01-2010, 17:00
  3. mk1 zephyr or zodiac
    By crumble in forum Vehicles - WANTED
    Last Post: 30-11-2009, 15:29
  4. WANTED; Mk1 zephyr parts.........
    By Joe Clay in forum Stuff - WANTED
    Last Post: 09-06-2009, 20:12
