Mk3 Capri V8 - Page 10
Likes Likes:  48
Page 10 of 12 FirstFirst ... 8 9 10 11 12 LastLast
Results 91 to 100 of 112
Thread: Mk3 Capri V8
  1. #91
    nowhere
    7,114
    2413
    nobody is offline
    Thats a proper ****er.
    Luckily no body damage
  3. #92
    Herts
    4,620
    224
    WB54 is offline
    duplicate.
  4. #93
    Herts
    4,620
    224
    WB54 is offline
    So after the fiasco of the car landing on the sump, I pulled the engine and box. While I had the sump off I though I'd check the big end as the oil pressure had dropped to 30 psi at idle when hot while breaking in the cam. It looks like it's had some debris go through them. Cranks not scored but does need a polish.
    I'm undecided as to whether to rebuild it completely or just reshell it on the assumption any **** is either in the bearing or filter. I think I'll be rebuilding it as the one of the mains isn't great at the cap join and if it's gone through the big end and mains, then odds are it's all gone through cam bearings as well.
  6. #94
    Rods 'n' Sods Junkie Paul L's Avatar
    Jun 2011
    London
    446
    7
    Paul L is offline
    WB54 – Sorry to hear you have more engine work to do after your car was hit on the driveway.
    Hope your luck improves for the rest of the build, Paul.
  7. #95
    Herts
    4,620
    224
    WB54 is offline
    Picking this one back up, I've been rebuilding the motor since the summer, between waiting for bits, waiting on people to do what they've said (and taken ****en ages) and a few hiccups, I should have everything back by next weekend to put the motor back together. The short block is done, crank didn't need grinding. I gapped the rings properly, took all the flash off the pistons, sorted the rust within the lifter valley, found out why the dizzy wouldn't seat as the driven shaft wasn't pressed into the lob fully. Managed to crack one of the heads pulling out the pressed in studs, double gutted as they've had spring seats and guides cut down, must had been cracked already as it literally just fell apart. On inspection though the heads were knackered **** assembled to sell. Valve faces all pitted, seats recessed, old springs shimmed up, valve tips all mushroomed. So a set of new Vortec 062 heads were sourced.
    The engine will now be upgraded to a roller cam with 276 duration and .502 lift. The heads have been worked over, I've mild ported the bowls, blended the seats, polished the chambers, backcut the valves, tapped rocker posts for screw in studs and had a 3 angle valve job. I'll be running comp retainers for clearance to the guide, LS6 beehive 375lb springs and comp magnum roller rockers. Last thing to do is port match the inlet. I've also stepped up to a Holley 4150 650cfm carb from the 600. It's better sized for the 355 and with the 110LSA on the cam it won't kill engine vacuum so will still be pretty responsive.
    I've just taken voluntary redundancy and will have January off before I start my new job, so I'm really looking to push as hard as I can to get the motor and box back in, finish up some welding on it, finishing the brake/coilover conversion and the get the 9in under it. At the minute I get 4-5 hours on it every couple of weeks and whatever I can do quietly on a weeknight. Having 3-4 weeks of full days should see the progress I need to get it on the road for spring. fingers crossed.
  8. Likessteve1275 liked this post
  9. #96
    9,194
    1774
    blackpopracing is offline
    Good luck & good luck with the new job.
  10. LikesWB54 liked this post
  11. #97
    Rods 'n' Sods Junkie 69 ford's Avatar
    Sep 2009
    East Yorkshire
    362
    18
    69 ford is offline
    Good luck with it all, never never give up.
  12. LikesWB54 liked this post
  13. #98
    nottafukinchancingham
    7,995
    61
    Torment is offline
    That's a ****ter about the heads Phil.. I have some Corvette ally jobs sat here doing nowt..
    57 chevy wagon.
    540cui altered.
  14. LikesWB54 liked this post
  15. #99
    Jun 2010
    yorkshire
    356
    9
    cougarv8 is offline
    THAT is some progress mate, nice.
    68roadrunner
  16. LikesWB54 liked this post
  17. #100
    Herts
    4,620
    224
    WB54 is offline
    Quote Originally Posted by Torment View Post
    cheers for the offer, i did consider new ally heads but the Vortecs are hard to beat price wise, i have about £500 and about 8 hours porting in them and they should be good up to about 450bhp
    1. MK3 Capri
      By Jungle_jim in forum Vehicles - FOR SALE
      Last Post: 07-11-2011, 09:33
    2. Mk3 Capri Bodyshell - FREE
      By WB54 in forum Vehicles - WANTED
      Last Post: 02-08-2011, 08:28
    3. Mk3 Capri Parts
      By WB54 in forum Stuff - FOR SALE
      Last Post: 28-07-2011, 11:47
    4. mk3 capri 30.s manual
      By morcheen in forum Vehicles - WANTED
      Last Post: 20-08-2010, 21:32
    5. MK3 Capri 2.0
      By snagwelda in forum Vehicles - FOR SALE
      Last Post: 19-06-2010, 11:25
