The Mu'Tang Clan - Page 2
Likes Likes:  46
Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 64
  1. #11
    Feb 2013
    uranus
    2,402
    ivanhoew is offline
    noice .
  3. #12
    Feb 2014
    Auckland NZ
    1,187
    2175
    legendlives is offline
    Still lovely weather here in NZ, so I dragged the bonnet outside.
    Filled the repair:
    Bare-metalled the whole bonnet:
    And gave it a couple of nice coats of Etch-primer and left it to bake in the sun:
  4. Likessteve1275 liked this post
  5. #13
    Feb 2013
    uranus
    2,402
    ivanhoew is offline
    satin black top coat ?
  6. Remove Advertisements
  7. #14
    Feb 2014
    Auckland NZ
    1,187
    2175
    Nah, not my thing.
    I'm thinking the new Hyundai grey/green, but it will probably end up white.
  8. #15
    Feb 2014
    Auckland NZ
    1,187
    2175
    Boot lid:
    "I'll just give it a buzz off then a coat or two of primer." Famous last words. The lid was quite rusty but had been coated (primed?) with some white stuff that was obviously made of unobtanium or similar.
    I tried everything: DA with 60-grit discs (this worked OK of sorts but would blunt the discs almost instantly), Sander with 60 grit sheet, sander with 40 grit sheet, grinder with flap-wheel. Nothing seemed to be truly effective so I resorted to 40 grit paper on a sanding block and then using just the edge. It took about 6 hours to get it down to clean-ish metal, then I realised that these holes:
    Weren't a spoiler mount but had been drilled to pull out the dent in that area. Out with the TIG and welded them up:
    Not pretty due to the thickness of the metal etc, but sealed up none-the less.
    A quick skim of filler and it was evident that the depression in the boot was quite large. Very shallow, but large:
    So after a quick spray over with rust inhibitor it was time for a couple of coats of etch primer.
    Had I been in the US I would have trashed it in an instant and been down to NPD before it hit the scrap pile, but I'm in NZ where these things just aren't plentiful.
    I might see the logistics of replacing it after lock-down, but for now at least it's presentable.
  9. #16
    Feb 2014
    Auckland NZ
    1,187
    2175
    Same deal with the roof today.
    Rubbed out, coat of rust inhibitor, 2 coats of etch primer and 2 coats of hi-build primer.
    From this:
    To this:
  10. Likessteve1275, justamin, mygasser liked this post
  11. #17
    Feb 2014
    Auckland NZ
    1,187
    2175
    More boring bodywork, but this time with modifications!
    After stripping the wings, a few holes became evident. These ones obviously from a side-repeater light:
    And this one at the base of the wing from???? Possible a trim piece or mud flap:
    After a bit of TIGgery, grindery and beatery:
    And then a small skim of filler-y:
    At this point I'd normally blab on about etch primer, but unfortunately I've run out!
    Leaving me the last resort of Red-Oxide primer:
    This will be coated with hi-build primer once it's fully cured.
  12. #18
    Sep 2009
    rothes scotland
    1,220
    169
    Duncan is offline
    Love it dude. I like the purple as something a bit different. If you’re looking for conversion mounts sump and headers they turn up quite often on the 429/460 page on Facebook.
    MY GARAGE AGAINST THE WORLD 8mm pitch blower pullys wanted pm me
  13. Likeslegendlives liked this post
  14. #19
    Feb 2014
    Auckland NZ
    1,187
    2175
    The RH wing went very similar to the LH one, except for the humungous series of holes that was the aerial mount:
    I don't know why Ford saw fit to bolt half a ton of (ugly) metal to the top of the wing just to mount the aerial. Even back in the 70's there must have been better options.
    Anyhoo, bare metal goodness:
    Followed by the usual weld, grind, red oxide and then a few coats of hi-build primer. Front end now has no side marker holes, trim holes or aerial hole:
    Apparently the weather is due to change a bit tomorrow, so the next step will be removing the doors to bare-metal & prime under cover.
  15. #20
    Feb 2013
    uranus
    2,402
    ivanhoew is offline
    whizzing along
