My 59 Pop Build - Page 19
Likes Likes:  8
Page 19 of 20 FirstFirst ... 9 17 18 19 20 LastLast
Results 181 to 190 of 195
Thread: My 59 Pop Build
  1. #181
    Rods 'n' Sods Junkie geof's Avatar
    May 2013
    middlesex, uk
    332
    233
    geof is offline
    Thanks, and very nice. My ball joints are Peugeot and 7.15, I too got the reamer from the states :-)
  3. #182
    nowhere
    6,690
    2327
    nobody is offline
    Manufacturers tolerance on ball joints is 1 degree
  4. #183
    May 2013
    middlesex, uk
    332
    233
    geof is offline
    Well after far to long, spent two days working on Pop, when I put the body on for a trail fit the wheels appeared to be pointing all over the place, so body off and did some measuring. I was pleasantly surprised, having built the chassis on the floor I was expecting to find I'd screwed it up, but all the measurements I took were within 1mm of so. The issue was the IRS was not straight in the chassis, its taken all day, but the radius arms are now fitted and its all adjusted and shimmed, what a pain in the as.... job that was. Still looks good now according the the string lines.
    Body Off
    Shocks installed
    String lines
    And no binding, job done.
  6. #184
    May 2013
    middlesex, uk
    332
    233
    geof is offline
    First real muck up, put the body back on and tested the rear suspension travel, ops the tyres hit the inner arches when the suspension is compressed. Bug..r Bug...r Bug..r, I failed to allow for the camber increasing on upward travel, and worst, didn’t allow for the fact the arches curve in so much at the top, real school boy error. Guess i’ll be cutting the arches up tomorrow and inserting 3/4 of an inch. Just when I though I was making progress.
  7. #185
    May 2013
    middlesex, uk
    332
    233
    geof is offline
    At last a few more bits done, body slowly getting bolted on as I work my way around it.
    Enlarged the inner arches, 40mm inserted , not fab, but once finished will do the job
    Front brake pipes mock up completed with mild steel now the stainless brackets to make
  8. #186
    8,775
    1757
    blackpopracing is offline
    Slowly getting there Geoff.
  9. #187
    Now a BIVA Build dlonamow(oldwoman)'s Avatar
    Nov 2010
    bromsgrove
    907
    886
    dlonamow(oldwoman) is offline
    just keep chipping away it will get done in the end
  10. #188
    Feb 2014
    Auckland NZ
    1,053
    1934
    legendlives is offline
    Quote Originally Posted by geof View Post
    I had a similar problem with mine. I'd got the wheel/arch clearance perfect but then realised the car was sitting too high. I ended up cutting out the entire arch and moved it up by 50mm.
  11. #189
    May 2013
    middlesex, uk
    332
    233
    geof is offline
    A few bits back from sand basting
  12. #190
    8,775
    1757
    Get some epoxy primer on them ASAP or it wont be worth having them done.
    1. pop build
      By scottrod in forum The Garage
      Last Post: 23-02-2017, 18:07
    2. pop build up
      By popleea in forum The Garage
      Last Post: 29-09-2012, 12:48
    3. my pop build
      By 1stpop in forum The Garage
      Last Post: 09-08-2012, 22:15
    4. My 59 Pop Build
      By SteveW in forum The Garage
      Last Post: 27-06-2010, 19:58
