My A35 bodied hotrod first build: Winter changes - Page 36
Page 36 of 38 FirstFirst ... 26 34 35 36 37 38 LastLast
Results 351 to 360 of 371
  1. #351
    Jul 2009
    Yeovil, Somerset
    1,762
    822
    Stroprock is offline
    Quote Originally Posted by 20vT_pop View Post
    You might find the shocks fairly ineffective at that angle unless they are very stiff, it would probably pay you to see if you can minimize the angle they are sitting at.
    John
    They are set at the same angle they were at stock
  3. #352
    Official RnS Addict Pughy's Avatar
    Oct 2009
    West Midlands
    633
    340
    Pughy is offline
    Quote Originally Posted by Stroprock View Post
    Hope so
    Good stuff, it's well worth it. Even if you end up just shaking it down around the pit area & campsite, it's still a blast
  4. #353
    Official RnS Addict harris66's Avatar
    Jul 2009
    solihull
    2,385
    79
    harris66 is offline
    Quote Originally Posted by Pughy View Post
    hot rod drags then.............
    i want cubic inches! lots of em!!
  6. #354
    Jul 2009
    Yeovil, Somerset
    1,762
    822
    After bleeding the brakes and fitting the prop I got back from MJC engineering (cheers Guy and Jonathon), I got to drive the car yesterday. Although it looks like the gearbox and engine need to come out cause I found a crack in the gearboxes rear servo across the casing. Never saw it till it was full of fluid
    Anyway, I plastered it with JB weld and gave it a blast up and down the track anyway, before I tear it apart.
    Not entirely sure I will bne able to use the B&M shifter either (sorry Paul!), theres too much play in the shifter itself, and I found yesterday that finding the right gear was more a question of moving the shifter until it did what I wanted it to do!!
    Would that be partly due to there being a leak and loss of pressure or something?
    Also fitted a red top facet fuel pump, hoping that will solve my overall lack of fuel going to the carbs.
    O
  7. #355
    23,355
    Excellent Kit, you've turned the corner now, you are no longer building it but repairing it instead !
  8. #356
    Jul 2009
    solihull
    2,385
    79
    harris66 is offline
    love it mate
    and no worries on the shifter, was worth a go
    get it fixed and hot rod drags!
  9. #357
    Jul 2009
    Yeovil, Somerset
    1,762
    822
    Quote Originally Posted by harris66 View Post
    love it mate
    Yeah, I'm pushing for drags
    With the shifter, does this box have a L1 postion on the lever from the side? Yesterday, it took ages to find the right gears and sometimes it would appear to be drive in every gear lever position
    Does a shifter from a car with a bw65 or even a gm180 have the same pattern and distances as the 35? It wouldn't suprise me if BL kept it the same so they didn't need to make so many differant parts
    Anyway, I have bought a new gearbox but want to get a trans shop to take a look at it before I put it in. Anyone know the sort of cost for this kind of check-up?
  10. #358
    Jul 2009
    Yeovil, Somerset
    1,762
    822
    OK, more work done. The B&M shifter wasn't working right since it is really designed for a TH350, so I decided I would use a shifter from a a car which had a BW35 fitted to save the trouble of matching the detents. I opted for an MGB one, and made a mount to fit. I had found that when strapped in, I couldn't reach the ignition or fuel pump switch , so they were moved to alongside the shifter too.
    But the biggest change was the gearbox. The first one was knackered (https://www.rodsnsods.co.uk/forum/tec...ty-63259/page2), so I bought another and fitted that (twice, don't got there!!), which fingers crossed, seems to be OK.
    Initially it was a bit tempermental with reverse, but after I adjusted the bands and got the carbs running much better, and I think it has improved.
    Also made some open exhaust headers:
    And found the wheels rubbed on the arches, so made some raising blocks which I'll fit when I get longer U bolts
    The rear suspension is too soft too, so new adjustable Gaz shocks are on their way
    Provided it behaves itself, HRDs is my target, but whether I'll actually take it up the strip this time I am not so sure
  11. #359
    8,961
    1770
    blackpopracing is offline
    Excellent work Kit, interior looks quite 'race car' now, well done.
    Look forward to meeting you at the drags & hope to see your car there too.
  12. #360
    Leicester
    5,696
    594
    bigyellataxi is offline
    Nice one Kit, it's all worth it in the end...!!!
    Fueled by Jim and Luckies.
    1. Alli Bodied Cobra
      By yorkster in forum On Topic
      Last Post: 17-05-2010, 19:40
    2. Anyone breaking a fox bodied Mustang?
      By StueyT in forum Stuff - WANTED
      Last Post: 16-05-2010, 13:10
    3. My 460 Build
      By fozwanger in forum The Garage
      Last Post: 25-03-2010, 23:42
    4. My kit build
      By 57peppershaker in forum The Shelf
      Last Post: 17-02-2010, 11:19
