Ok take two, as all the previous text was lost, here is my latest acquisition a '37 Ford (Matford) with the 2 1/4 flathead V8, as seen on ebay, unusually for me it was just down the road, it is running and driving, although it does have a leaky water pump, and a very smokey engine, the selle thoughtfully provided water pump overhaul kits and NOS pistons and head gaskets ( he did also say that the smoke was jus a bit of oil in the exhaust pipe, but the fact that the section that the oil might accumulate in, is rotted away tends to suggest otherwise!)
F** k me I've only worked out how to post real pictures instead of those f**cking thumb nails, (turns out if you follow the "how to post pictures" advice, it works)
Not the best conditions to take photos (apparently) but you can probably see I've made a start, removing the bulbous awfulness of a boot, and started on the frame to make it a slant back.
