Old Lemon Consul Capri
Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 52
    Official RnS Addict Special When Lit's Avatar
    Derby
    1,270
    593
    Special When Lit is offline
    Some of you might remember my Capri, it is the one featured being built in Street Machine, in the late 90's.
    I've had it since 2007, & other than changing the wheels, have mainly just used it as is.
    I knew it had a few bodywork issues, not helped by sitting on my drive under a cover for 6 years.
    Last summer, I had a garage built, & decided to take it off the road & sort it out.
    I'm in no rush to finish it, gonna take my time & do it as & when.
    Before.
    Think it might be a few years before I get am 'after'!
    Worst part so far is the rear valance/boot floor area. Almost all filler. :****er:
    O/S A panel/door pillar.
    Double skinned. Both were rotten.
    O/S A panel.
    O/S chassis rail.
    Front panel.
    End of front panel.
    If you can't be an example, be a warning.
    Derby
    1,270
    593
    New piece made & fitted.
    Then I took the 'screen out. Wish I hadn't....
    Derby
    1,270
    593
    Don't know why some of the pics are on their side?
    Official RnS Addict ROCKIN WOLEY's Avatar
    Eating JAFFA'S In The Workshop
    3,624
    1953
    ROCKIN WOLEY is offline
    Nice to see you got it on hear Gaz.
    Did'nt think it was that bad, but small potatoes for your experience plus it would be a real shame to it rot to death,
    Anyway keep the pics comming Gaz
    Jeff
    Injection is nice but I'd rather be Blown
    CHARNWOOD CRUISERS
    Aug 2011
    Hertfordshire
    1,742
    Scaf is offline
    Gaz, good luck with the rebuild, your certainly have your work cut out with that, but it will be worth it.
    By the way, the Pinball is working perfectly !
    Rods 'n' Sods Junkie Rob_Che's Avatar
    Aug 2009
    Oop North
    250
    23
    Rob_Che is offline
    I don't fancy that work around the screen but you look more than capable looking at the repairs so far, good work!
    23,343
    You need to be quick with the repairs ofr the original steel left will start to rot as well . Rust never sleeps , especially on a Consul Capri .Stuff that may have had a few pinpricks when covered with filler just keep on rusting away
    6,225
    1037
    English Impala is online now
    Quote Originally Posted by Special When Lit View Post
    There's some filler in that front panel! It should weigh a lot less when you've finished with all that lot removed.
    Rods 'n' Sods Junkie supateach's Avatar
    Oct 2013
    rotherham
    180
    129
    supateach is offline
    I remember it well, it was around at the same time as my former car 'satans pawn'. don't get disheartened, my celica was as bad as this, if not worse, see pro street Mk1 celica post in this area, I started cutting rust out 20 years ago and finally have it painted, I am sure you will, but make sure you put epoxy primer on immediately after you have welded in the patches to stop the rust starting again, just scuff it rough with 60 or 80 grit and get it covered as soon as possible, I made the mistake of leaving some areas after I made then and they had started to surface rust within a week as you can see from the rear tubs in the pics, normal primer, either celly or 2k is porous and will let water through and the steel will rust under the primer, look forward to seeing it finished hopefully in less than 20 years like mine took
    Official RnS Addict 1stpop's Avatar
    isle of sheppey kent
    2,484
    48
    1stpop is offline
    Ouch , that didn't look that bad at all, shame just hope you like welding
    Dazza
    1. Hi from Cheshire - "Old Flame" Consul Capri
      By stu460 in forum Who are ya ??
      Last Post: 11-08-2012, 12:46
    2. Looking for my Old consul Capri from Hayling 87 - 88
      By gibo993 in forum Who are ya ??
      Last Post: 10-02-2012, 16:02
    3. Consul Capri
      By Acker in forum Vehicles - WANTED
      Last Post: 18-05-2010, 15:51
    4. classic consul capri bumpers
      By spider in forum Stuff - FOR SALE
      Last Post: 11-05-2010, 21:09
    5. consul capri parts
      Last Post: 11-09-2009, 08:49
