project colin 1963 morris minor - Page 11
Likes Likes:  29
Page 11 of 81 FirstFirst ... 9 10 11 12 13 21 61 ... LastLast
Results 101 to 110 of 802
  1. #101
    Now a BIVA Build dlonamow(oldwoman)'s Avatar
    Nov 2010
    bromsgrove
    910
    886
    dlonamow(oldwoman) is offline
    why the double adjustable end for the track control arm.
    wouldnt the rose joint on the end be enough
    ye see what you mean but if there is a fixed bush one end (rubber) would'nt you need to make the rod longer or shorter for adjusting the bar , i could turn the rose joint around 180 deg but that would only give me half a thread pitch adjustment woud'nt it ??
  3. #102
    Nov 2010
    bromsgrove
    910
    886
    Quote Originally Posted by fozwanger View Post
    What time are you in in the evenings? I have sat for the last 2 days for over 2 hours each evening getting thru the road works on the M5. When can I drop in? (Can't do Tuesday or Thursday eve BTW)
    I got your PM, just haven't got round to ringing yet......
    im in around 5 ish every night got no life
  4. #103
    nowhere
    6,954
    2392
    nobody is offline
    i use unf rose joints so half a turn is probable half a mm.
    done a set yesterday and had no probs when i put them in.
    not sure how much adjustment you would need.
    once fitted they never need to be adjusted again,i only use a rose joint for any slight missalignment
  6. #104
    Nov 2010
    bromsgrove
    910
    886
    thanks for that, never thought how much one half a turn would be, ive made them now so will give them a bash anyways
  7. #105
    Lee
    Fat 'n' Loud Lee's Avatar
    Derby
    4,766
    493
    Lee is offline
    At least you can adjust them in situ rather than having to unbolt the rose joint.
  8. #106
    Nov 2010
    bromsgrove
    910
    886
    nearly finnished the track control arms and dropped the gearbox on before i make new mounting brkt, anyone know what the ideal angle for the engine / gearbox should sit at
  9. #107
    Jul 2009
    Yeovil, Somerset
    1,762
    822
    Stroprock is offline
    usually its 3* down at ride height, measured from the gearbox flange. But what is most important is the diff and the gearbox are parallel, so if you do set it at 3* down, the diff needs to be 3* up (at ride height remember!!). Google 'pinion angle' if you want a better explanation from someone a little smarter
    Love the build by the way, anything morris minor on here catches my eye
  10. #108
    Nov 2010
    bromsgrove
    910
    886
    cheers strop checked it last night! as i am running the jag rear that is set up at 90 deg to the floor so i only needed to jack the gearbox up about 10 mm to make them parallel so my bearing should run a nice Elliptical pattern (got that on the interweb)
  11. #109
    8,977
    1770
    blackpopracing is offline
    if running a jag rear end different rules apply.
    I 'think' you keep the engine at 3 degrees leaning back, the oiling and inlet are set up for this. Also it aids the motor running under you in a big accident.
  12. #110
    Nov 2010
    bromsgrove
    910
    886
    are thanks blackpopracing i have only just made my gearbox brackets so i can cut another 10 mm of the bottom of them thought it funny that the engine ran flat i will crank it back 3 deg
    i have started on the rear shock mounts i was going to run my shocks horizontal but it would of cost to much probably do it later when i have got more cash
There are currently 2 users browsing this thread. (0 members and 2 guests)
    1. morris minor project ( cheap!)
      By patricklambert in forum Vehicles - FOR SALE
      Last Post: 24-10-2010, 21:50
    2. Morris Minor project £150. Now with more pictures.
      By StueyT in forum Vehicles - FOR SALE
      Last Post: 13-03-2010, 15:19
    3. morris minor rolling shell project
      By kevpop in forum Stuff - FOR SALE
      Last Post: 08-03-2010, 07:49
    4. Morris Minor Engine
      By Mad Mark in forum Stuff - WANTED
      Last Post: 04-03-2010, 07:14
    5. Morris Minor Rust Project - Essex/Herts Area
      By Bigdawgv8 in forum Vehicles - WANTED
      Last Post: 03-03-2010, 13:54
