hi there , finally started on the car , i removed the old front end and stripped the viva axle , i removed 5inch and welded it back together with my new birthday pressie . I now need to remove the rear axle so i can set the ride height,
Hi keith, good look with the build , shame about the prefect front end, I personaly like them as they look like a mini pilot.
I`ll watch on this build post more pics as you progress.
Cheers Dave (ex Bratfud lad)
hi 1961desoto, not sure if he is on this site, the body had already been cut up into a cab with what looks like a moggy cab back, the glass wind screen was cracked a lot and all the filler on the front wings was flaking off, it also had a jag back axle on it. Cheers for now....................
hi, i got the son in law to remove all the rear end (he wants to help), i m using a sierra back axle with locost wish bones and uprights, im copying COSSIE POPs idea (loosley), he s on the other channel. Im toying with the idea of a subframe , fitting all the parts in one unit and being held in place with 6 bolts with poly bushes , this will allow for easy fitting and any repairs to be done, has any one got any thoughts about this idea?. More pictures as and when. see ya...............
Hi, I'm using a Sierra diff on my build it took quite a lot of design work to make sure all the rear suspension geometry works with the the correct angles throughout the whole suspension travel. Obviously I don't know you're skill level I feel Cossie Pop made life difficult for himself initially and he has a mate who does his machining, if you can machine stuff then no problem but if you can't you may find it either expensive to get done or not possible. Are you gong to narrow the rear end? if you aren't then it probably would be better if you are a novice at car building or welding to see if the complete rear subfame from the sierra could be made to fit, then all the geometry would be ok. But if you were going to narrow it then you would have to start from scratch, You would probably be better off fitting a Volvo axle on a four link with watts linkage much simpler to set up and easily strong enough for the v6.
However if you proceed with the build as started best of luck with it and I will be watching your progress I have a soft spot for the prefect myself as I built and owned one for 26 years.
John
My Pop Build thread Hidden Content
My 55 Chevy Resto Hidden Content
Anyone can drive a fast car, not everyone can drive a car fast!!!!
hi
ive put a sierra diff in a mini befor.
made the hub carriers and then made custom A arms to suit.
for the driveshafts as it was only running a rover on the street, i cut them,sleeved inside,then sleeved on the outside.
seriously cheaper than having new ones made.
had a look a couple of weeks back ,at one in a pop and he had got something seriously wrong as camber was excessive and one wheel was pointing away from the car
good luck and keep the pics coming
Hidden Content | Hidden Content | Hidden Content | Hidden Content | Hidden Content
You should consider and mx5 rear axle and subframe.....na will be fine but nb geometry is better, (na-mk1, nb mk2.)
hi ,thanks for all your thoughts , i suppose what i am really trying to emulate is the locost idea and geometry, yes the drive shafts will need shortening as will the top and bottom a arms, the top arms have some adjustability for camber , there is also adjustability for toe in or out. Thanks............
