Reliant Buggy
Likes Likes:  31
Results 1 to 10 of 31
Thread: Reliant Buggy
    Official RnS Addict 29stude's Avatar
    Nov 2009
    chesterfield/derbyshire/uk
    779
    666
    29stude is online now
    Reliant Buggy
    This won't be to some tastes and definately falls into the sod category . But hopefully of interest to some.
    Project started as a way to use up a few left over bits and pieces from previous projects, and as a bit of a field car for my kids to drive around the in-laws field.
    I wanted to build something that looked like a mixture of: Home built special/vintage buggy/classic trials car. But didn't have any set design in mind, so it's just evolved as I've built it.
    As with a lot of projects, it has got a lot more involved than first planned, but I enjoy the process of fabricating random parts into something useable.
    Decided to build something big enough for me to drive as well my kids. So needed reasonable sized engine, chassis and body.
    For power I looked at various small/cheap 4 pot engines (A-series/austin/etc), in the end found a Reliant Rialto 3 wheeler which gave me aluminium engine, gear box and rear axle, all these are pretty light and can be lifted by hand.
    To keep in the old car theme, I found a cheap, rotten (ID less) Ford Pop chassis on Ebay, this provided front axle and rear wishbone. as a bonus, I managed to sell remaining parts from it and recoup most of the initial cost.
    Couple of pics below.
  2. LikesDuncan, Torment, alleykat, steve1275 liked this post
  3. Remove Advertisements
  4. #2
    Nov 2009
    779
    666
    Build has been done as time permits, so stuff has'nt always been completed in a logical sequence, but I'll try and put it in some sort of order.
    Wheel base is based loosely around Morris 8/Ford Pop. I've used Ford Pop front axle complete with leaf spring and wishbone.
    Rear axle is Reliant Robin on Ford pop leaf spring and wishbone. (rear wishbone located with a 4X4 ball joint). Machined tapered bush to hold ball joint.
  5. LikesTorment, alleykat liked this post
  6. #3
    Nov 2009
    779
    666
    2 reliant props joined using homemade sleeve. Not been balanced, so just tacked together for now, will have to see what vibration is like.
    Frame for body made using box section.
    Exhaust made with few Ebay bends and cherry bomb silencer.
  7. Likesalleykat liked this post
  8. Remove Advertisements
  9. #4
    Nov 2009
    779
    666
    I bought some aluminium to clad the frame. Had to pay extra to have some prefolded for floor, but saved a little by digging throught steel merchants rack of scrap stock for other stuff.
    Added some beads to panels to break up the slab sided look, then hammered them over the top of frame.
    Transmission tunnel.
  10. LikesTorment, alleykat, hurtz liked this post
  11. #5
    Nov 2009
    779
    666
    As I want the grill to look like a cast aluminium piece (as much as possible). I've used thicker gauge aluminium plate and tack welded it together.
    Only got MIG welder to work with, so have been using a short torch and argoshield gas, this is normally for steel, so doesn't give the greatest finish. However as its not structural, it will have to do for now, until I can get a bottle of correct gas and fully weld it.
    Got a cheap router from Ebay to radius the holes. This was mounted in hand drill using homemade holder.
    That's it for now, thanks for looking.
    Gav.
  12. Likes28Chevy, alleykat, hurtz, steve1275 liked this post
  13. #6
    Dec 2010
    Near Canning Town, London
    1,904
    2011
    Taxirod is online now
    Love it! Good use of otherwise unwanted bits, already looking good, should be fun.
    "Share with a wise person, and he will become wiser" - Proverbs 9:9
  14. #7
    Feb 2010
    Essex
    787
    dodgeman is online now
    I wish I'd had someone build me something like that to mess around with when i was a kid.
  15. #8
    nowhere
    7,033
    2406
    nobody is offline
    thats pretty cool. you should be able to use it in 2036 when were allowed back out again.
  16. Likesalleykat liked this post
  17. #9
    23,467
    Looking great ! If you are off roading it then reinforce the back axle tubes as they are ( very) thin wall and prone to bendimg in hardtail trike configurations.
  18. #10
    Nov 2009
    779
    666
    Quote Originally Posted by Taxirod View Post
    Quote Originally Posted by dodgeman View Post
    Thanks chaps
    Cheers Kev,
    Rear axle under went a slight change (but not worked out how I can post those pics as they are in RAW format). I will have a look at a way of strengthening tubes.
